It's like your ears are being stressed. Just an unnerving feeling. I have no idea what was causing it. I've never experienced it before outside of possibly an airplane? It was noticeable within 5-10 minutes and persisted the entire test drive. Here's something else I found online:
"I suspect that the air inside the car is vibrating the way it does inside an organ pipe or in a soda bottle when you blow carefully across the bottle's lip. This resonant effect is common in cars when one rear passenger window is opened slightly. In that case, air blowing across the opening in the window is easily deflected into or out of the opening and drives the air in the passenger compartment into vigorous vibration. In short, the car is acting like a giant whistle and because of its enormous size, its pitch is too low for you to hear. Instead, you feel the vibration as a sickening pulsation in the air pressure.
For the one-open-window problem, the solution is simple: open another window. That shifts the resonant frequency of the car's air and also helps to dampen the vibrations. Alternatively, you can close the opened window. In your case, the resonance appears to involve a less visible opening into the car, perhaps near the rear bumper. If you can close that leak, you may be able to stop the airflow from driving the air in the car into resonance. If you are unable to find the leak, your best bet is to do exactly what you've done: open another window."
