How wide is the bed (inside dimension)?
Discussion in 'Cybertruck: Interior & Exterior' started by Hookemhorns, Dec 22, 2019.
  1. Hookemhorns
    Hookemhorns Member
    Georgia
    I think I read Elon talking about a 4x8 sheet of plywood with the tailgate down, so I assume the interior width of the bed is at least 49 inches. Anyone know/have a guess how wide it is?
  2. keeney
    keeney Member
    Minnesota
    In other threads, the widest I have heard mentioned is 57 inches wide which seems proportional to the photos and would be a nice wide amount of room between the wheels (but not as wide overall as conventional pickups have outside the wheel wells). I have yet to see a Tesla-published spec of the bed dimensions other than the nominal length being 6-1/2 feet. Conventional pickups have the wheel wells at around 49 or 50 inches apart for good reason - so as not to rub on the tires. Making the inside of the bed wider than that would require getting 4 more inches of clearance from the inner edge of the tire on each side. If they push the rear wheel track out wider, that could do it, or maybe they make the suspension more precise. A conventional solid rear axle needs to be able to tilt quite a bit and there is a lot of clearance around the wheels. Maybe with independent suspension, less side to side clearance is needed.
    The inside ends near the tailgate also appear to taper out slightly wider.
  3. keeney
    keeney Member
    Minnesota
    Examining some more actual photos (and the renderings), I am suspecting the interior sides of the bed taper slightly outwards vertically as well. It may be a few inches wider at the top than at the floor. I wonder if this explains some of the variance in bed width dimensions that have been reported.
    Notice in this photo the slightly darker triangle back by the Tailgate. If the sides were vertical, that crease/seam between the side and the triangle would stay vertical. But its angled.
  4. lafrisbee
    lafrisbee Active Member
    Indialantic FL
    I think that is because the tailgate slopes out, not the sides.
  5. S3XY
    S3XY Active Member
    Buffalo, NY
    Agreed. Also notice that the right and left edges of the tailgate are not angled. They are parallel with all of the anchor slots. Speaking of those slots, if we knew the spacing of them we could probably figure out the width of the bed with a fair amount of accuracy.
  6. keeney
    keeney Member
    Minnesota
    I still think this shows that the sides are sloped out. If the sides were vertical, then the triangle piece would be a rectangle and its front edge would be vertical, not angled.
  7. lafrisbee
    Indialantic FL
    Alright, I'll try to get you to come around another way.... For one, go look at photos of the tailgate from a quartering angle it slopes in from top to bottom from the outside.
    And give this some thought..How could you tie ANYthing to the side of the bed if it is angled. And what would happen when you put something in there that fit at the top but didn't fit at the bottom?
  8. LavenderFemChi
    Staten Island, NY
    Does anyone know the height of the bed with the top down.. I am looking to use the Cyber Truck to transport my Permobil wheelchair of course I would have to have the seat back so its flat. Thanks.. I understand.. that final specs are not available.
