HPC error cable strain
FlasherZ
Sig Model S + Sig Model X + Model 3 Resv
Jun 21, 2012
7,024
1,013
I'm not familiar with HPC's, but the NEC code requires that the EVSE provide interlock equipment to prevent cables from being stretched too far. I suspect there's some type of a strain switch in it that is tripped or malfunctioning?
Feb 15, 2012
11
0
Austria
what the hell .... ! i blocked the switch, i also fixed the cable as strong as i could, nothing helps, always the same error "cable strain"
somebody with similar experince?
thanks
manfred
FlasherZ
Jun 21, 2012
7,024
1,013
Wish I could help you... I know nothing about the Roadster HPC's. Perhaps that switch is bad?
Feb 15, 2012
11
0
Austria
now i made some Pictures of the HPC:
first the controllerboard, in my opinion all connected correct
on the second you see the inside, green+red+black for connecting power, purple for the connection Signal, no further modification
on the third you see that i decomposed the cable strain switch and fixed it. there i found the small green plug, i don't know whats the function of this one, there is no free cable to plug in.
and the last Shows the cable strain LED flashing
PLEASE HELP ! i Need this thing to work. any hint? or is somebody able to make a picture of inside his own HPC so i can compare?
thanks
Manfred from the middle auf europe
PVG199
5
Signal Hill, CA
Hi Manfred..
Were you ever able to figure out the problem? I am now faced with the exact same issue and I know what the fix involves, but I don't know the steps.
Basically, there is a reset procedure that needs to be performed to make the "cable strain" error message go away. It involves some combination of pressing the "reset" button a prescribed number of times but for the life of me I can't remember the details. (I was able to reset it last year, but stupidly didn't write anything down).
So, if maybe you've found this same information, it would be great if you could tell me. If not, I'll keep looking and maybe I can post it here if/when I find it.
Regards,
Patrick Gough (California)
