Is there any benefit getting a HPWC if the on board charger max out at 32 Amp with a NEMA 14-50? I originally thought the HPWC would allow me to charge the car at 48amp if I have a 60amp breaker, but someone told me SR+ only charge at 32 amp from either the UMC or HPWC. I am so confused.
The benefits of an HPWC:
1. Hardwired means fewer connections.
2. The UMC can stay in the car.
3. The cable is longer.
4. Okay for outdoor use.
5. Can coordinate two cars.
6. If you put it on the maximum circuit you can use PlugShare and support the max charge rate for all cars.
The advantages of UMC:
1. Cost
2. If you get two cars, unless your electrical service is very low, both cars can charge at the same time. (Two circuits, one for each).
3. Any EV can use a 14-50 (some require adapters that don't come with the car).
Basically, if you only keep the UMC in your car when you travel, then the UMC is the lowest cost solution. If you frequently take the UMC with you or you need one of the other benefits, then the HPWC is the way to go. If you go with the HPWC, it's not a bad idea to also install a 14-50 as a backup in case the HPWC needs service.
