HPWC cable button is no longer opening the charge port anymore? Any fix?
Aug 31, 2017
43
40
Menlo Park, CA
I have a 2017 Model X P100D
I have a silver HPWC Gen 2. Everything worked perfect for past couple years.
Then I had an electrician move the HPWC to another wall. Everything works fine as far as charging, I get the full 72A.
However, the button no longer works to open the charge port.
The car is unlocked, my key fob and regular charging cable still open the port without any issue.
From my research here, it sounds like there is a transceiver in the wand that has gone bad.
I've tried pointing it at rear hatch, being super close, far away, etc. It does nothing.
Is there any way to repair the button part, or is the only way to get a new HPWC?
Any idea of how it could have went bad? Maybe handle got dropped when moving?
Thanks for the help!
Jillmark99
193
50
Ontario
I wouldn’t replace the HPWC. Just tap the door with your finger and it will open and then plug in the charger.
Hardly worth spending $700 on a new charger for that.
Just my 2 cents.
Reactions: jboy210
ShawnA
880
653
Edwardsburg, MI
Hi Impetuous,
If you purchased the charger by itself the warranty is for 12 months.
If you purchased it with your car, it is covered by the 4 year or X mile vehicle warranty.
It might be worthwhile to contact the charging team.
It could be fixed or repaired by a mobile technician...
Good luck,
Shawn
jboy210
4,673
2,902
Northern California
Just my 2 cents.
I do the same when I don't want to wait the 20-30 seconds or so it takes for the car to come out deep sleep and get all it's radio receivers working.
Aug 31, 2017
43
40
Menlo Park, CA
Hi Impetuous,
Good luck,
Shawn
I didnt even know you could purchase it with the car, I just purchased it as an accessory with the car. I was hoping there was a quick fix like repairing a piece inside the handle or swapping something. Looks like I could possible just swap wall charger and sell old one as working with the disclaimer of the button on ebay.
Aug 31, 2017
43
40
Menlo Park, CA
So there is an actual home charging support line for Tesla (650-681-6133).
I called them up. They had me reboot the Tesla with scroll wheels and try again - no dice. They had me do hard reset again - no dice. Killed power at breaker - no dice. I also updated the firmware to 2020.4 without luck.
They confirmed it doesn’t work and checked my receipt and will send me one under warranty.
They checked the part number and asked what the last letter of the part number is. Mine was E.
E apparently represents the firmware version of the wall connector. They said they’ve seen the button fail a bit recently, but only on the version E after a couple of years.
They said the version H is the latest and will try and source the gen 2 H and will send it to me in about a week, unless I want the Gen 3 (they have that in stock and ready to go).
I didn’t realize I would receive one under warranty so I already had a signature wall connector I purchased that was a version H. I swapped out the wall charger and the new one works now.
I sold the old one (with the disclaimer that the button doesn’t work). So I’m back in business now. Just wanted to post an update.
Qbenjamin
Frugal But Classy!
Jan 7, 2017
1,139
673
Braavos
I'm using the mobile connector and it's hit or miss at times to open the charge port door (60/40). A light press on the door with a finger usually opens it for me.
