HPWC charging at only 16 AMPS on Model 3
Discussion in 'Model 3' started by MXWing, Aug 4, 2018.
  1. MXWing
    MXWing Well-Known Member
    Model 3 charges at 16 AMPS / 240 says HPWC is only partially plugged in.
    Charging light is yellow.
    Tried reseating plug several times and reset HWPC. Connectors look fine.
    Model X charges at 48 AMPS consistently at no problem.
    Model 3 charging with Model X charger gets 40 AMPs and green charging light.
    Any ideas?
    Wondering if I should have withheld the check to Tesla until I could have tested my HWPC at home. ;)
  2. MXWing
    To add on, it acts like it attempts to "negotiate" a charging rate and I hear internal clicking.
  3. P85_DA
    P85_DA Supporting Member
    You broke it already ??:eek:....is the yellow on charge port or yellow on wall connector ? I’m sure u know this already as the yellow on WC is because it reduced Amps due to heat ...if yellow on car port it’s the connection between WC and charge port is not seating correctly ..
  4. P85_DA
  5. MXWing
    Yes I busted it!
    It's yellow on the car port. Tried inserting and reseating a few times. 16 AMPS. Plugged in Model X, boom back to 48 AMPS.
  6. P85_DA
    That link above guy had same issue ..guess u got to jiggle the handle to seat properly in port to engage :(
  7. MXWing
    I will try it later! charging offsite now at the inlaws. Need that high SOC to slaughter random BMWs in town.
    I owe you a drink for trying no matter the outcome.
    Hope it fixes the issue however. Symptoms seem identical. Surprised it isnt a more common issue.
    Most Model 3 owners just using mobile connector?
    Model X Mobile Connector is charging it now..
  8. P85_DA
    Probably just tolerances in the port ..I have seen some handles that are too tight to fit in the ports ..
  9. MXWing
  10. MXWing
    We need Tesla branded personal lube.
    For charge ports and short sellers.
    • Funny x 7
  11. kutkuzak
    kutkuzak Patrick
    Indiana
    My wife's model 3 developed the same problem today. Not sure of fix yet.
  12. gilscales
    gilscales Active Member
    Long Beach, CA
    #12 gilscales, Nov 19, 2018
    From another thread
    Cleaning supplies:
    Spray the DeoxIt on one of the brushes and clean all the contact surfaces. Then use the swabs to remove all the dirt and dry the contacts.
    Looks like it is common for the connection area to start failing due to dirt build up
    Would definitely turn off breaker to HPWC before cleaning !
    Video on DeoxIT
  13. smatthew
    smatthew Active Member
    CA Bay Area
    I may be wrong, as I don't spend much time staring at Tesla connectors, but I believe the handle has "self-wiping connectors". Designed to cut through corrosion and ensure a good connection.
  14. eprosenx
    eprosenx Active Member
    Beaverton, OR
    A small plastic piece of your Model X charging port has broken off and is lodged inside your wall connector plug. When inserting it into the Model 3 it acts as spacer and keeps the plug from inserting all the way. Since it came from the Model X there is no additional spacer issue so it works fine there.
    I am on my phone so I am not going to go searching the forums for the pictures / examples, but I have participated in threads about this. There was also a Reddit thread on this with good pictures that I answered.
    A couple folks have fixed the issue by heating up like a pin or a drill bit hot with a candle and shoving it into the plastic piece and letting it cool. They were then able to extract it and get the charger working again.
    Your Model X then needs service on its charge port to replace the broken charging port.
    (I could be wrong, but these symptoms sound like a ringer for the solution I describe above)
  15. gilscales
    Long Beach, CA
    You could be right, I got the info I posted off of this thread
    Charge port & cable connector cleaning
