You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
The Generation 3 Wall Connector manual indicates the following:
"Power Sharing Overview
This feature will be available in a future over-the-air firmware update.
The firmware-based power sharing feature enables up to 16 Wall Connectors installed at the same site to intelligently share the site's total available power via unit-to-unit Wi-Fi. This minimizes the need for many residential and commercial applications to have specific electrical upgrades for concurrent multi-vehicle charging."
Has there been any indication of when this update will be made available? I just had 2 of these installed and need to balance power sharing over what's an otherwise over-provisioned circuit. Unfortunately, the generation 2 HPWC are no longer available and they'd used a physical connection between them.... with generation 3 wifi is employed (but evidently not yet enabled).
