HPWC GETTING HOT WITH CHARGING
Discussion in 'Model X: Battery & Charging' started by Chickenlittle, Sep 1, 2018.
  1. Chickenlittle
    Chickenlittle Active Member
    Virginia
    i use HPWC to charge my X and model3. Noticing hey connector getting quite hot when charging the X (used to be just warm). The model 3 (charges at lower amp) now gets warm. The connector appears clean. Anybody with similar experience?
  2. P85_DA
    P85_DA Supporting Member
    What amps are u charging at ? It does get warm on max for the X of 72a if ur car is capable of ..if u has wall connector for awhile I would check the torque on the wires as well
  3. Chickenlittle
    Virginia
    Thanks great idea. Guess I should check both in unit and at the breaker. Yes am using at 72amos
  4. harry
    harry Member
    Prince Edward Island & Wisconsin
    Heat is a symptom of resistance. Even though the nozzle may look OK, there is sometimes oxidation on one or more of the pins. I charge our S's at 80 amps, and every few months the connector starts to heat up while charging. Spraying some non-flammable contact cleaner into the pin areas cures the problem for another few months.
  5. bkp_duke
    bkp_duke Active Member
    San Diego, CA
    If you are seeing heat on your cable, you are most likely hearing your fans in the car spin up to keep the pack at the optimum temp. Both of which means you are losing efficiency and energy to heat production.
    A little birdie at Tesla told me that for OPTIMUM battery longevity, keep the charging rate at 20-25A. Faster if you need it that day, but for optimum battery life, that's the "sweet spot".
  6. mspohr
    mspohr Well-Known Member
    I usually charge from my HPWC at 32 amps. Everything stays cool and there is always enough time overnight to finish charging. Much more efficient (I^2 R) and much easier on all of the equipment.
  7. bkp_duke
    San Diego, CA
    That's great, but I wasn't talking about charging efficiency. Per my friend at Tesla, the engineers have told him that for optimal battery LONGEVITY and minimal range degradation, 20-25A is optimal.
  8. mspohr
    Thanks for this information... maybe I'll turn it down to 25.
