I'll ask again: Is the theory of operation of using a PWM signal for a DC coil contactor that you are reducing a rectified 340V DC voltage down to an average 240V by adjusting the pulse on time? ie. the PWM signal is "on" 240/340 = 70% of the time? Or are you effectively reducing the power, and just letting the coil see the high voltage, but for a shorter period of time? Presumably you are assuming a 240V DC coil can take short periods of 340V? Wouldn't the rectifier and capacitor by itself reduce the DC voltage well below the 340V DC peak anyways?
I'm just trying to understand why a PWM signal is better than a resistor - I guess the overall power usage is less, even without a lower power hold circuit?
