HPWC LED Issue
Discussion in 'Model S: Battery & Charging' started by sashner, Mar 27, 2016.
  1. sashner
    sashner Member
    New York, NY
    Recently had my HWPC installed. Realized my electrician made a mistake and left the DIP switches in "test mode" so I shut off the breaker and changed them to be in 80A output. When opening the HPWC cover, I accidentally broke the LED cable off of the motherboard and now it is inoperable. The HPWC works fine however. As long as it is working, do you all think its safe to continue using or do I need to go back and buy a new HPWC? Since the LEDs are used for diagnosing errors in charging I feel like I am fine.
  2. FlasherZ
    You will be fine unless the WC fails.
  3. Darryl
    Darryl ModelXTracker.com Co-Adm
    Palm Beach FL
    First there is no 80 amp mode. There is a 72amp mode to be used on a 100amp circuit with 2-2-2 copper wire. You should be able to send the HPWC in for repair. It shouldn't cost over '$100 to fix as the HPWC is $750 unless you are a member of a state club.
    Do you have a 14-50 outlet you can use in the meantime?
  4. MikeBur
    MikeBur ManualPilot
    Seattle, WA
    Agree on getting it repaired.
    Not heard that HWPCs are now limited to 72amps. ModelX vehicle is limited to 72Amp draw maximally, Model S 80Amp (when using dual chargers).
    My best info is my own manual and page 12 from: https://www.teslamotors.com/sites/default/files/blog_attachments/ms_hpwc_installation_guide.pdf
  5. sashner
    sashner Member
    New York, NY
    The S charges at 80A with dual chargers. Do not have a 14-50 outlet
    If its working properly, why do you believe it should be repaired?
  6. siai47
    siai47 Member
    Deland, Fl.
    My HPWC (which came with the car) is configured for 80 amps on a 100 amp circuit and delivers 80 amps to the car. I think there are different versions of the HPWC out there---Maybe Canadian models with different settings with 72 amps as a limit per building codes?
  7. mrElbe
    mrElbe Active Member
    Stouffville, ON Canada
    Here in Canada - 80 Amps dip switch setting on 100 Amp breaker circuit.
  8. FlasherZ
    Darryl, there are several things in play here. First, the wall connector will advertise 80A to any electric vehicle plugged into it when configured for a 100A circuit, regardless of Model S or Model X. A Model S configured with dual chargers can use the full 80A offered, while Model X configured with a 72A charger will obviously use up to 72A. This is why it can be confusing when you talk about its use on Model S vs. Model X - the charging equipment can do 80A but the car can't so it limits to 72A.
    Also, in the US, you may not use 2-2-2-4 NM cable at all for the 100A setting, and you may not use 2-2-2-4 SER cable if at any point it passes through or in thermal insulation... just a quick note for those there; Canada allows for the use of NMD90, I believe.
    The front LED panel has no control logic and therefore, unless you *need* the lights on the front panel, it doesn't harm the HPWC to operate it without the front panel LED's. You may want to call Tesla to see if they can send you a new faceplate, but it won't harm operation in the meantime.
  9. AndreSF
    AndreSF Member
    San Francisco, CA
    Is the ribbon that connects front panel LED repairable? Or just see if service center can order you a replacement part.
  10. FlasherZ
    Here is my whole quote:
    I structured the sentence oddly, causing confusion - I meant that for the 100A setting 2-2-2-4 couldn't be used if it passes through or in thermal insulation. It could be used at any setting less than 100A circuit rating on the HPWC, just can't be used for the 100A setting. My apologies.
  11. AWDtsla
    AWDtsla Active Member
    NE
    Yeah I just realized that a minute before your reply... thanks.
