HPWC outdoor install?
Discussion in 'Model S: Battery & Charging' started by Cheerose, Mar 4, 2013.
  1. Cheerose
    Cheerose Member
    Las Vegas, NV
    For me, it would make a bit more sense (at least in theory) to have a HPWC outside. Is that possible/are they weatherproof?
  2. Arnold Panz
    Arnold Panz Model Sig 304, VIN 542
    Miami, Florida
    I was told absolutely yes -- it can withstand a hurricane. You'll want to make sure you have a good electrician do the install, because the sturdiness is only as good as the installation. The cord is unbelievably thick and can probably handle any sort of weather.
  3. Al Sherman
    Al Sherman It's about THIS car.
    Batesville, IN
    Maybe mount it so it can be covered with just the wire sticking out the bottom of the cover? Possibly someone on here has done this already. Or plans to.
  4. artsci
    artsci Sponsor
    Timonium, Maryland
    I checked months ago with Tesla. It can be installed outdoors. But as Al Sherman suggested, I'd make a cover for it to shield it from rain.
  5. brianman
    brianman Burrito Founder
    Nobody had one installed when Sandy hit, AFAIK. Would have been a great test...
  6. gardnerep
    gardnerep Member
    Mendon, Mass
    Anyone have picturs of an outdoor installation? I would definetly would want to put the HPWC in an enlosure to protect it from the elements.
  7. scaesare
    scaesare Well-Known Member
    NoVA
    The unit body is made of similar plastic (ABS) to that of which weatherproof electrical boxes are made of, and is also covered by a rubber material layer. In addition the cover is gasketed to prevent water intrusion, again as outdoor electrical enclosures are. Finally, the cable fitting appears to be of the water-tight variety.
    Hmm... after writing all of that, I decided to go look at my manual... sure enough it's rated as a NEMA Type 3R enclosure, which is rated for indoor or outdoor use.
    The primary installation concern would most likely be ensuring a weather-resistant connection to your source electrical circuit. You have to drill a hole for a 1" conduit connector. You would want to select and install an appropriate rated connector there to ensure the integrity of the enclosure.
  8. TheAustin
    TheAustin Model X 90D (Former Model S P85)
    The Hamptons
    I've had my HPWC installed outside for almost a year, and it's been totally fine...I didn't have any other place to put it (no garage) so it had to go on the side of our work studio, so I checked extensively with Tesla and many people at Tesla assured me that it could be installed outside. And I don't have any kind of shelter/protection around it, it's fully exposed to the elements. Go for it, you should be fine.
  9. scott2613
    scott2613 Member
    Wisconsin
    Here is one along with a CS-100 that's been outside since August. They've been through lot's of rain and a snowstorm and haven't had any problems yet.
  10. Jwarrenphd
    Jwarrenphd Member
    NC, USA
    I've installed one outside my office. The electricians said perfectly okay.
  11. Cottonwood
    Colorado
    Here is a picture of the HPWC's on pedestals at the San Diego Service Center:
  12. invisik
    invisik Supporting Member
    Minneapolis
  13. bhzmark
    bhzmark Supporting Member
    Anyone have suggestions, links, part numbers for appropriate metal (or perhaps wood) mounts for outdoor installs of the HPWC?
  14. mrElbe
    mrElbe Active Member
    Stouffville, ON Canada
    #14 mrElbe, Nov 9, 2014
    Here is my install beside the driveway awaiting arrival of car in "Late December". Just a pressure treated 4x4 post with an attached 2x4 to make a 4x6 to accommodate the HPWC width. Solar LED on top for decoration.
  15. ArtInCT
    ArtInCT Always Learning
    Southern Connecticut
    The Milford, CT Tesla Service Center has two of them mounted outdoors with electrical conduit plumbing.
    I did inquire about this and the service manager stated that the HPWC is rated for outdoor duty.
  16. TES-E
    TES-E Member
    Casa Grande, AZ
    Mine is outside... no problem.
  17. hingisfan
    hingisfan hingisfan_Mark_V
    Kingston, Ontario
    Are you guys burying the wire from the post to the panel? Is it as simple as cutting a hole and running the wire? Is there a minimum depth?
  18. mrElbe
    Minimum depth is as per local electrical code. My wire is in 1 1/4" conduit ( 1" would have done) buried 2 feet. I already had 100A service in the garage. I also installed a digital meter in the line so I know how many KWh I use for charging from the HPWC without depending on the car readout.
  19. scottm
    scottm Active Member
    Canada
    our code is this yours is probably similar:
    use a proper rated cable or conduit for underground
    bury 18" min, so go 24" depth, unless you're crossing a roadway, then bury 5 feet
    cover the cable in trench with sand minimum 6" around all sides
    if you're trenching along with other services put a 2x6 pressure treated plank between the services
  20. Cottonwood
    Colorado
    Separation from medium Voltage distribution lines is 2 feet in my area, but that is usually not a problem because those have to be at least 4 feet underground. Always do a utility locate (usually free), and when backfilling, put some construction plastic, yellow, warning tape 6-12 inches above your conduit to make it easier for future generations to miss. Utility locates will not always find private runs.
    Because most of the cost is in the trenching, I always use conduit, and go up a size or two from the minimum. The larger conduit will make for easier pulls and will allow for future upgrades. For example, the HPWC has a knockout for 1" conduit. Do most of the run in 1.5" conduit and neck down to 1" in a junction box near the HPWC. It seems obvious, but make sure the bends are done with sweeps and not elbows. I once had a contractor (not an electrical contractor) put in elbows. He paid for the retrofit to sweeps, but it made for an extra delay, and more muddy holes.
