Reddy Kilowatt
2-3 romex is what you want to run $6.14 a foot was my price at local supply house it is a 4 conductor cable. they don't offer 2-2 Romex. Copper only, do not use Aluminum.
I stuck with the 6/3 NM Romex (4 wires) for a 42A charge. it was only $1.74/ft which is a lot cheaper. I thought I might get a 100 series at some point but that is so far away I'll deal with it then. I also thought I would need a second unit but will add it later when i really do need it, and will pull a second cable. which is still cheaper than the big cable. The 2-3 gives you future flexibility to use an outlet which is a 4 wire requirement.
I see the cut sheet you have for the SER shows a un-insulated ground, most of the cables I see only has a braided ground that you have to twist in to a stranded conductor. it looks like hell and I don't think you could get that under the ground lug in the HPWC, and could break it trying. You would be foolish to try it. It's not worth the cost difference. ( I might be thinking of USE cable)
