HPWC - single phase 32a
Discussion in 'Australia & New Zealand' started by championi, Jun 13, 2016.
  1. championi
    championi Member
    Sydney, Australia
    Hey guys,
    Just wanted to ask a question, I have a HPWC connected on a single phase 32amp circuit. My model S only has a single charger.
    What charging rates should I be getting? I swear I used to get 50km/hr but the last few times I'm getting a charging rate at 33km/hr. Does this seem right, or am I getting my wires crossed?
  2. NovoCasGreeny
    NovoCasGreeny Member
    Newcastle, NSW
    P=IV.....240*32=7680 W or 7.68 kW per hour maximum.
  3. championi
    championi Member
    Sydney, Australia
    Thought I was getting around 50km/hr ??
    Weird.
  4. Blue heaven
    Blue heaven Fair Dinkum Tesla
    South West Australia
    33-34km range per hour is about right for that set up.
    Did you charge at a 3 phase HPWC elsewhere? That would have been about 54km range per hour with single charger.
  5. championi
    championi Member
    Sydney, Australia
    Thanks guys for the clarification.
  6. raynewman
    raynewman Active Member
    Brisbane, Australia
    The standard Tesla setup is 40 AMP and hence over 40 km/hr. Note all this discussion is with 'typical' set. If you change your settings to 'rated', you get a whole new ball game.
  7. championi
    championi Member
    Sydney, Australia
    Ray, your an absolute legend! That's what it is.
    Thanks so much mate.
  8. championi
    championi Member
    Sydney, Australia
    Hey Blue heaven,
    Thanks for the reply.
    No I haven't used a 3 phase HPWC elsewhere. As Ray mentioned I did change from rated to typical. This is what caused the different ranges I've seen.
  9. paulp
    paulp Active Member
    Adelaide, Australia
    Or you could use the dumb mans equation that 1amp = 1kmh of charge, roughly.
  10. NovoCasGreeny
    Newcastle, NSW
    Good rule of thumb Paulp when charging with single phase. 3 Phase would change it up a bit though.
  11. paulp
    paulp Active Member
    Adelaide, Australia
    Indeed it would. Solar also increases it a bit in SA as our power from grid is under 230V, but with solar its over 240.
  12. PJF000
    PJF000 Member
    Australia
    times 3
  13. Dborn
    Dborn Confirmed
    Sydney, Australia
    About 5 km per kW/hr. 200wh per km.
  14. Bullet1
    Bullet1 Electric - way of the future
    Gold Coast, QLD Australia
    Quick bit of help needed re Off Peak connection if anyone can assist?
    I am sctracting my head at the moment.
    Just connected 3 phase HPWC today on T31 off peak. Most of the time the HPWC is not powered up, so don't think it will open charging port? I am assuming I can open the charge port from main screen, connect, have car programmed to charge during off peak times and when off peak is live between 1pm and 7am then hope the car talks to the HPWC and charges so I wake up all ready to go?
    Any experiences with off peak connections?
  15. Tubbers
    Tubbers Member
    Sydney
    Probably I should let someone answer that knows what they are talking about. But I will let you know my understanding. (Not that my tesla has arrived yet).
    The charge port can be opened from screen. When the wall charger gets switched on by the off peak, it waits a random amount of time before changing (a few mins). This is to prevent many chargers kicking in on a grid simultaneously after a blackout. So I assume the off peak works like a blackout recovery.
    I don't think you need to set charge timings on the car. It will just charge once the flow of off peak starts. (I think you use the charge timers if you have a new "time of day" electricity meter that charges differential tariffs at different times. For this you would set the car to charge only at cheap times (even though a live charger is attached)
    Hope that helps (and isn't wrong ;-)
  16. Mark E
    Mark E Member
    Sydney NSW
    My charger is connected via to off peak power via a contactor @32A. You are right that when there is no power the button on the charger won't open the charge point but you can do that from the screen or using the key fob. I just hold the boot (hatch) button on the fob for a few seconds and it pops open. You can use the schedule to start charging but there really isn't any need - once the power is on the car will start charging on it's own.
  17. Bullet1
    Thanks for the rundown. Didn't realise the fob opens the charger port so this is perfect.
