Thanks for the photo. Yes I was confused, now I understand!
FWIW, the Tesla Charging Support Team will inform you that the only approved wiring method for the HPWC is permanent on a dedicated branch circuit.
While the HPWC Installation Guide does not specifically state that a flexible power cord is not allowed, it only includes guidance for a permanent/hardwired installation.
The HPWC is a UL listed device (UL 2594 Standard) and as such the installation must comply with the manufacture installation instruction or the UL Listing is void and the equipment is therefore not acceptable to the NEC.
Also, the NEC restricts the length of the flexible cord to 12 inches when allowed, however for the Tesla HPWC the flexible cord is not an approved wiring method as per Tesla.
I wonder why that doesn't apply to, say, electric ranges or electric clothes dryers?
I put a 14-50 on a HPWC and set it to 64 amps by the dip switches but then dialed it down to 42 amps in the car. That way, the load is split 50/50 on my dual chargers for less wear on each since after 40 amps the car splits the load.
Those appliances are typically installed more permanently, and in dry locations. The 12" maximum cord requirement is designed to keep most of the cord subject to the interlock and ground-fault protection offered by the EVSE, especially since they're used in damp/wet locations.
If you want to draw 80A from the HPWC, the NEMA receptacle is not capable of more than 60A. That is the reason why HPWC is direct connected. But you can of course limit your HPWC current draw to something that is within the capacity of the receptacle, but there is always the danger of having a wrong setting and causing circuit overload that will lead to overheating and possible fire. I am speaking of the electrical installation external to the car, i.e. cables, circuit breakers, receptacle, connectors, etc.
Unless there is a need for portability, I would prefer hardwired connection over plug/receptacle.
I'm not 100% sure, but I don't think it works that way. I think it utilizes the full capacity of the primary charger first, then engages the secondary. I've noticed that when I connect to an 80 amp source, it will ramp up to 40 amps, then hold for a bit, then continue ramping up to 80.
That tells you it's splitting the load. Try it at 56 amps and watch it ramp up to 28, then hold for a bit, then go to 56.
Question on power distribution using dual chargers at 40 amps charging current.
True, but if all I want is 20A or my panel cannot handle the 50A for full capacity UMC, then I will not get a HPWC, an UMC with the proper adapter will suffice for me. This is according to Tesla Sales Advisor.Yes, you must set the internal dip switches for a 50 amp circuit (40 amps delivered). But remember, you can hard-wire an HPWC into circuits of lower capacity too... right down to a 20 amp (16 amps delivered) circuit and you must also set the dip switches accordingly. Not all HPWCs are wired into 100 amp circuits.
I'm not aware of any adapter that can provide 20A on 240V on the UMC...True, but if all I want is 20A or my panel cannot handle the 50A for full capacity UMC, then I will not get a HPWC, an UMC with the proper adapter will suffice for me. This is according to Tesla Sales Advisor.
You can dial it down to 20A on your touchscreen.
Yeah... I have a couple of those... I was referring to an actual UMC connector.There are adapter cables available that will convert a NEMA 6-20 to a NEMA 5-20, and then you can use the Tesla 5-20 adapter. The UMC and car don't care whether it's 120V or 240V. The adapter is fairly dangerous, though, and needs to be labeled thoroughly so someone doesn't blow up 120V-only appliances with it.
You're really allowed to feed a Nema 14-50 with less than 50amp? I know this is technically legal for a regular 14-50 but here in Canada, if a outlet is used for an EVSE, regulations are not the same.
