HPWC / UMC2 to Roadster adapter
Discussion in 'Roadster 2008-2012' started by richkae, Mar 13, 2013.
Tags:
  1. richkae
    richkae VIN587
    I want a Model S to Roadster adapter.
    I would actually prefer a Model S inlet on my Roadster but I would settle for the adapter.
    I want to use a Model S UMC for my Roadster on roadtrips and I want to be able to use Model S HPWCs when they exist in the wild.
    I am tired of waiting for Tesla to offer a solution, I have no idea if they ever will. Who else is interested in doing it independently?
    I am hopeful that with a large enough volume we could interest someone with the skills to make them at a reasonable price.
  2. ChadS
    ChadS Last tank of gas: March 2009
    Redmond, WA
    I agree - the Model S already outnumbers Roadsters, and soon will overwhelm them. I assume Model S owners will soon be installing enough HPWCs to overwhelm HPCs as well. So upgrading the Roadster, or at least giving it an adapter to use HPWCs, seems like the best solution. (Then we could change the HPCs in the wild to HPWCs, and all Tesla owners could use all Tesla chargers).
    It doesn't look like Tesla is going to work on it any time soon - in fact, they have given no indication that they are thinking of doing it ever - so it will have to be a third-party solution.
  3. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Currently there is reportedly a bug whereby if the EVSE offers 75A or 80A the Roadster refuses to charge. Until Tesla fixes that I don't believe the HPWC will work, regardless of the connector.
  4. ChadS
    Redmond, WA
    Ouch. Yeah, that's an issue. If Tesla doesn't offer an adapter, they probably won't fix the bug. So maybe 3rd party is impossible.
    Unless it's a smart one that also lowers the amps...but I think that will be more expensive than most of us would be interested in. I was hoping for just a dumb physical adapter.
  5. hcsharp
    hcsharp Active Member
    Vermont
    I made a prototype a couple of months ago but then stopped working on it. And yes, it overcame the bug that prevented the Roadster from charging when the pilot was > 70A. If you can wait, I'm going to start working on this again at the end of April. I'm straight out with my regular job right now.
    I stopped for several reasons. 1) We cancelled our Model S order and the nearest one is 1.5hrs away and it's helpful to have one of their chargers around. 2) It was a lot of work to get the "smart" part of it working reliably and I didn't know when Tesla would fix the bug and render all my work obsolete overnight. 3) My business is a bit seasonal and I'm straight out right now. The soonest I can start working on this again is late April. 4) I got sidetracked making a Roadster plug to J1772 connector (prototype only cuz I wanted one but probably not going to produce these). 5) I also got sidetracked making a Tesla II connector (Model S connector) because a lot of DIY types have asked me for that.
    Can you wait a couple months?
  6. richkae
    richkae VIN587
    Yes. Just having a plan and a timeline is very helpful. Knowing this is coming frees me to participate in installing Model S HPWCs in the wild.
  7. Tesla 940
    Tesla 940 Member
    Santa Fe & Taos, NM and Long Beach, CA
    I'm interested
    I have your 1772-Roadster adapter. Tested once to make sure it works (your suggestion) and sure enough it did. I would also be interested in a MS-Roadster adapter.
  8. 100thMonkey
    100thMonkey Member
    Seattle area
    this sounds like the solution. the fact that we have so many different plug types is already getting a bit crazy, especially considering how big the network would be here in WA/OR if only everything were compatible. We've got J1772, CHAdeMO, Roadster, Tesla S and all the Nema plugs). this lack of compatibility threatens to slow the advancement of the charging network due to indecision and duplication of resources, which threatens to tame enthusiasm for adoption of the cars. we are so close to saying we can go anywhere in WA and OR pretty conveniently if only for lack of compatibility and backwards compatibility. it's a bit frustrating. I would think that Tesla would see it as a big PR/marketing thing and step up the adapter production and keep the costs way down, even subsidize them. Having broad compatability through adapters will give those of us who are grappling with the EV skeptics a formidable tool to win arguments and minds.
  9. richkae
    richkae VIN587
    To solve the 80amp pilot signal problem do you just consume the pilot signal and regenerate your own?
  10. hcsharp
    Vermont
    Sort of. You have to keep the "revised" pilot signal exactly in sync with the original.
  11. samcarney
    samcarney Sam C
    Great Lakes, Sonoran Desert
    Originally Posted by hcsharp viewpost-right.png Can you wait a couple months?
    I would also be interested in a Mod S to Roadster adapter
  12. bonnie
    bonnie I play a nice person on twitter.
    Columbia River Gorge
    Put me on the list for those who want to charge their Roadsters on HPWCs, Henry.
  13. Doug_G
    Ottawa, Canada
    Problem is, you can't charge a Roadster on an 80 HPWC. There's a bug in the Roadster that causes it to not charge if the EVSE reports 80A. Tesla has never fixed it.
  14. wycolo
    wycolo Active Member
    WA & WY
    So maybe a breakout box in the Roadster trunk to highjack both signals? Sending a variable, but 75A max, signal to Roadster. And a variable request signal to EVSE. Both start at low levels of course. And our promise to use only with great restraint. :smile:
  15. hcsharp
    Vermont
    And at the rate they're going, they probably never will! That's why I took matters into my own hands. Read the whole thread.
  16. Botbldr45
    Botbldr45 Member
    Sedona, Az
    hcsharp
    I would also like to be put on list for new adapter ....
    i thought you got rid of roadster and got a S ...... Must be someone else on threads
    J adapter is great so I'm sure this one will open new horizons for the fanatic few with east coast roadsters!!
  17. hcsharp
    Vermont
    Still have my Roadster and no immediate plans to sell it. I work on this project a little bit every day between my day job and my family... One thing I've learned is that it's a big step between a prototype and something you can actually manufacture!
  18. Botbldr45
    Botbldr45 Member
    Sedona, Az
    One thing I've learned is that it's a big step between a prototype and something you can actually manufacture![/QUOTE]
    Words to live by ........
    Ever go down to Boston and meet the head Ranger, Mat at the Service Center?
    He is a good guy ............... liked the J adapter
  19. BryanW
    BryanW R#664, Model S#1526
    Utah
    My preference would also be to upgrade the Roadster inlet to a Model S inlet, but if that is not in the works, please add me to the list interested in a MS-Roadster adapter.
  20. hcsharp
    Vermont
    Did he know who made it? Or did you have to tell him?
