HPWC / UMC2 to Roadster adapter
bonnie
I play a nice person on twitter.
Feb 6, 2011
16,427
9,739
Columbia River Gorge
Just curious if anyone is still experiencing difficulties using the SR. Henry sent me three - count them, THREE, and I couldn't get any of them to work at either the Torrance SC or a neighbor's HPWC. All three worked on a Roadster 1.5 but not on my late production 2.0. Any thoughts on what might solve my charging issue? Do you think Telsa changed things when moving from the 2.0 to 2.5? FWIW - my JR works fine.
Has your Roadster software been updated to handle an 80amp pilot signal?
hcsharp
3,370
1,337
Vermont
Tesla 940's car is a bit of a mystery. I don't think it's the 80A charging bug but not sure. His car has failed to charge using CAN-SR on every MS charger he's ever tried (a total of 4). Most other people find an average of 1 out of 20 that don't work. Two of those chargers (that Tesla 940 tried) have worked multiple times on another Roadster and one of them has worked on a 2.5. I've got another 2.5 test scheduled for later this month on the same HPWCs. When the data comes in from that I'll have more thoughts.
djp
Model 3 Performance
Aug 28, 2011
1,120
59
Toronto, Canada
Hmm.. I have VIN 939 (I assume Tesla940 is one ahead of me). I'm still in queue for a CAN SR, but happy to do some testing with local HPWCs to see if it's related to our production batch.
NigelM
Recovering Member
Apr 3, 2011
13,386
555
Northern Virginia
I had the FW issue back up-thread after erroneously believing I was on the latest version. You have a neighbor with a HPWC so he should also have a Model S UMC? It's worth trying out the UMC and seeing if that works. If it works at the lower amperage then it's definitely your Roadster FW that needs updating.
miimura
5,998
5,577
Los Altos, CA
Why not work with the neighbor to open the HPWC and temporarily change the DIP switches to lower the pilot? I would think that would conclusively determine if that Roadster still has the 80A charging bug.
hcsharp
3,370
1,337
Vermont
That's a good idea, and the same method another person used to determine he didn't have the latest firmware. But he sent me a video and it looked like a different problem. It would be easier to just check his firmware version.
dhrivnak
4,389
3,516
NE Tennessee
Yes it could be the firmware. My SC claimed I had the latest firmware. After a few references to TMC they sent someone out to upgrade me as they did not, after all, have the latest firmware to install when the car was serviced. But with nudging they found a later copy and I was impressed they made a special 300 mile trip to see me. With the CAN SR and the right firmware I have not had an issue.
NigelM
Recovering Member
Apr 3, 2011
13,386
555
Northern Virginia
Data points after ~2 weeks testing: the CAN-Sr has worked perfectly on 5 'B' versions and 5 'D' versions of the Model S HPWC. One of the 'B' HPWCs on an island here has a (theoretical because it fluctuates) 208v 60A feed where my Roadster pulled 213v and 47A and the CAN was flawless.
Thanks again Henry.
hcsharp
3,370
1,337
Vermont
Thanks again Henry.
Thanks for the report! I love news like that! I'm building them whenever I can sneak time from my family and job and it shouldn't be too long before I get through the list.
Strib
90
Alamo, CA
I know this is an old thread but thought I'd jump in. I'm hoping to acquire 1 each of Henry's SR and JR CAN's because it sounds like the right solution for me (I'm on the list for a Model X, in 'who knows?).
But for those interested, Colin Flynn, Mgr. of Tesla's Charging Installation Program was rather encouraging that they'd soon have the Roadster HPWC available again.
I called the Torrance, CA Service Center and the Service Manager stated that if my car was serviced in the last year (which it has) it would have version 4.6.8 (the latest). When I asked if there was some way to verify that, the SM stated that the information regarding FW versions was not visible on the VDS. So... does anyone know how I can verify the FW version?
As for asking my neighbor to "open up" his charger - I'm really hesitant to take that approach. He's a neighbor, who is nice, not necessarily a friend - if you know what I mean.
Thanks
AEdennis
2,712
937
Thanks
It's probably quick for them to check... Just swing by the SC and ask them to verify...
pharma5
Roadster F#25, Model 3 #36xx
Nov 22, 2011
555
113
central NJ
Pull a log file on USB stick, and look at it with the Graphical Log Parser (available via http://www.teslaflux.com/).
There's an arrow button on the bottom ">", which leads to firmware history as one option. (At least that's what I do. Thanks Doug_G et al!:biggrin:).
hcsharp
3,370
1,337
Vermont
He has a 2.0 so they can do it remotely. Tesla can download his log file in a lot less time than the USB stick transfer. But it might be easier to do it himself and get the answer right away.
smicker
Roadster 1020
Apr 15, 2012
163
324
Berlin, Germany
Thanks Henry!
NigelM
Recovering Member
Apr 3, 2011
13,386
555
Northern Virginia
There's the red flag. The SM is assuming you have the correct FW, meaning that he didn't actually check; my Service Center only received the latest FW a few months back (August IIRC) but my last service was in April.
Pull the logs on a USB and the easiest way to see the FW version is just open the file on a PC with 'Editor' and use Ctrl+F to search for the word "firmware". You need firmware 4.6.8
wiztecy
2,905
563
When you first turn your key on, the firmware version is quickly displayed in the upper right hand corner of the VDS screen. Its in really small font, so make sure you have your reading glasses on or a camera recording in video.
