So much for J1772 being a standard!
Honestly, it's a pretty weak standard that leaves a fair bit open to interpretation.
AFIK Tesla has never tried to claim their EVSEs are J1772 compliant. They only claim their cars are generally compliant (with an adapter). Even then they don't guarantee you can charge with every J1772 EVSE. And in fact you can't.
Fair enough, but my comment still stands. If the standard was better defined all these compatibility problems would not be present, and Tesla would have absolutely no reason NOT to follow the standard.
I remember Elon saying on a conference call that the Model S uses J1772 signaling and debates over the physical connector are misguided since it's easy to build an adapter. Devil is in the details apparently.
His comment only applied to the car (with adapter), not the Model S charging equipment (HPWC and UMC). Now we're trying to use chargers that aren't necessarily compliant with a car that's not necessarily compliant. I think Tesla had good reasons for everything they did, but it means we have a little sorting out to do.
Does this mean the adapter now needs its own active logic and J1772 signal generator, or it is still a passive straight-through connection?
Ever notice that Roadster HPCs always give you 70A, not 69A. Even if hooked up to a Model S (mine has a J1772 cable now so I can charge my S faster on those rare occasions)? And the HPWC gives you 80A, and the UMC 40A, yet every J1772 station I've connected to gives you one amp less?
It started out with logic but I was able to do it without a microcontroller. Then Tesla came out with a firmware update and a very simple passive filter was all it needed. Now I'm not sure what it will take.
I always thought that was a Model S thing. I have a DIY charger that produces a 70A pilot and most Model S' display 69A when connected but my Roadster charges at 70A on the same EVSE. Someone told me it's only the display, which rounds down, and that the MS is actually charging at 70A based on the kW reading. I haven't done enough testing to know for sure.
Three distinct problems have been identified. More than I expected. I've developed solutions for 2 out of 3. The third issue is still evasive. Progress is being made however and I will solve it sooner or later. There were some revisions to the HPWCs and UMCs so that some work and some don't. The Roadster 1.5 PEM is also a little different from my 2.5 so it's hard for me to test those cars. I'll post updates here when there is news. I'm spending a lot of time on this.
I have a Roadster 2.5 and a BRAND NEW Model S HPWC from TESLA because my old unit decided it was time to retire. I am happy to do testing for you if needed.
I hope things are going well!
I'd vote for ship now. The Roadster isn't compatible with all J1772 stations either (Schneider as an example) so I think a 95% rate is pretty good.
If the failures are limited to a few old HPWCs and the new ones work 100%, then absolutely ship.
I've got about a dozen adapters in circulation right now. The success rate is better than 95%. In other words it will charge on at least 95% of the Model S HPWC/UMCs that exist. I'm not sure what to do right now. Should I start shipping them because everyone is tired of waiting, or should I wait until I reach 99% or better? It's possible that it will never work on 5% of HPWCs no matter what.
