4 motors might become a thing in expensive electric sports cars, and some heavy duty applications like trucks, but that's the only place you're going to see them. The performance increase isn't worth it for normal driving. For heavy duty applications, it can give a truck more horsepower to move big loads, but the torque and HP n a passenger car with just 2 motors is way more than sufficient.
Hub motors have another problem over axle mounted motors, you need to get the power to the motors and on something that spins, you need to have contact brushes which are another thing to wear out. The contact surface on a wheel also needs to be a sealed system or water and dirt will be getting in there on a regular basis. As the contacts wear, one of more motor is likely to cut out unexpectedly, which could lead to accidents. For safety the car would need a system to monitor the state of the contact between the motor and electrical system and shut down the car if it's compromised. Even then there could be electrical failures the system couldn't anticipate.
The idea with most EVs is to reduce the number of parts that will wear to increase reliability. Expensive sports cars tend to be a lot less reliable than passenger cars because it's assumed the buyer is willing to trade reliability for that last iota of performance. All but the most die hard gear-heads want their daily driver to be as reliable as possible.
For any number of motors, an axle mounted motor makes much better sense from a performance and reliability standpoint. Hub mounted motors are one of those things that could be done, but there are a lot of drawbacks.
