Humming sound after car is parked
Discussion in 'Model 3' started by Twolemons, Feb 28, 2021.
  1. Twolemons
    Twolemons Member
    Canada
    Hi guys,
    I am new to Tesla and just picked up my M3SR+ today. I noticed that after I parked andl eft the car and locked it, the car still makes a humming sound from the frunk. Maybe it is from the heat pump. I tried manually turning of climate control and it still has the sound. Is that normal? Does it go away in a while after the car is parked?
    Thanks.
  2. XPsionic
    XPsionic Member
    los angeles
    It's normal. The car's just shuffling heat around to optimize battery/motor/interior temps.
  3. dmurphy
    dmurphy Woof.
    New Jersey - Morris County
    As @XPsionic said, it’s totally normal. You’ll even hear noises at somewhat random times - maybe hours after driving. It’s completely normal. The car runs its pumps and fans and things when it needs to. You’ll appreciate that in summertime when it never lets the cabin get excessively hot.
    Very different from a traditional car where it’s either “on” or “off”. This thing is a giant rolling computer and so it’s always running in some form or another.
    Congrats on the new car — you’ll love it.
  4. treadpool
    treadpool Member
    Boston
    Definitely takes some time getting used to some of the unique sounds these cars make :)
  5. Twolemons
    Twolemons Member
    Canada
    Thank you very much for your help!
  6. Gasaraki
    Gasaraki Active Member
    Syracuse, NY
    Yes. Your car will make noises even when it's "off" cause technically it's not really off.
  7. BeeGood
    BeeGood Member
    Yup, like others have said totally normal. The heat pump resetting, the fan running low-speed to dry out the condenser, etc. Like @dmurphy said, the car is never actually “off”, but it will eventually “go to sleep” when it’s done.
    You’ll get to the point where you’re concerned when it doesn’t make any noises. :D
  8. stopcrazypp
    stopcrazypp Well-Known Member
    #8 stopcrazypp, Mar 2, 2021 at 4:12 PM
    It might also be because you have cabin overheat protection turned on, see page 127 in manual:
    https://www.tesla.com/sites/default/files/model_3_owners_manual_north_america_en.pdf
    Otherwise it's normal the car makes some noise when it's "awake" as it maintains the battery temperature (although not the cabin temp if you have the other features turned off). Eventually after the car sleeps (you might hear a "thump" from the back as it opens up the contactors and disconnects the high voltage battery), then it would be completely silent. When you wake up the car again (you can see in the app when it says "waking") you will hear a "thump" from the back as it connects the HV battery again.
    To minimize the energy use and let the car sleep, you can also disable Sentry mode (p 141) and and Summon Standby (p 108).
