HVAC temperature - changes on it's own?
Discussion in 'Model S: User Interface' started by TrevTremaine, Feb 1, 2018.
  1. TrevTremaine
    TrevTremaine Member
    Toronto, Ontario, Canada
    Good Evening, I have been finding over the past few days that the temperature in my car changes without me doing anything. My wife is the only other one who has access, and she's assured me she's not pranking me. I had my suspicions for the past couple of days, but today I actually caught it actually changing. I had it set to 21.5C by it set it down to 18C all of a sudden while I was parked for about 10 minutes. Nothing touched or prompted.
    Has anyone else experienced this lately?
  2. TLej
    TLej Little-Known Member
    Edmonton, Alberta, Canada
    Nope. Stays just where I set it. You wouldn’t have changed it in the app doing a preheat maybe?
  3. David29
    David29 Supporting Member
    DEDHAM, MA
    I have experienced, or at least suspected, something similar but have not been able to put my finger on exactly what/when. I will try to keep an eye out.
    It seems to happen when getting in/out of car, as you said, or when changing profiles -- it seems to remember a temperature associated to a profile.
  4. gastowatts
    gastowatts Member
    TX
    I noticed this is over last week or two as well. I thought it happened when I adjusted the temp from the app and then when I got in the car and started driving it reverted back to the earlier setting from before the change I made from the app. I haven’t recently used the app for temp changes and haven’t noticed a recurrence.
  5. CBPfromTN
    CBPfromTN Member
    Nashville, TN area
    Question about the a/c. When your car is parked and the a/c is still cooling, does the fan blow out the same volume of air as it does when your car is moving, driving?
  6. Mediocrates
    Mediocrates Member
    San Diego, CA
    I've noticed that the actual fan speed will vary (presumably for temperature regulation to the target temperature), even if you manually set the target temperature, fan direction, and fan speed. It's one thing I dislike about the climate control in a Tesla and is different from all other vehicles I've owned/used.
  7. TrevTremaine
    TrevTremaine Member
    No, not in this case. I had preheated the car before leaving (22.5C), adjusted it while driving (21.0C) but it seemed to change on it's own (18C) when it was parked after about 10 minutes with me sitting in the car.
  8. TrevTremaine
    TrevTremaine Member
    Interesting point about the profile. I'll see if that might be it, but I doubt it as I unbuckled when I parked (ie. changed the profile), and the temperature remained constant for a time after that.
    About the only possibility I can think of is that my arm brushed the right toggle wheel on the steering wheel but even that seems remote especially since it's in "Entry Mode" and therefore I've got the steering wheel pushed in and up all the way. It's far enough away at that point I doubt my arm would even come close to brushing it.
  9. BinaryField
    BinaryField Member
    Earth
    I've experienced this on several occasions before as well. I would use the app to warm up the cabin before getting to the car. Some time after entering and beginning my drive, I would notice that the temperature setting had returned to its previous value. It seems intermittent. I'll try to keep an eye out next time to see if I can reproduce it consistently.
  10. CBPfromTN
    CBPfromTN Member
    Nashville, TN area
    I don't like that either. If I am hot and I want the A/C on, I want it blowing out of the vents at high speed if I turn the fan on high. That's weird. I could see the fan not running as high/fast if the car is just parked in a parking lot but once it starts driving, I feel if I set the fan on high it should come out on high....
  11. TrevTremaine
    TrevTremaine Member
    I got the 2018.4 update yesterday, so I'll have to see if this happens any more. The release notes never really drill down to what bug fixes have been addressed, so testing (somehow?) will happen.
  12. sandpiper
    sandpiper Active Member
    Ontario, Canada
    So, I had this happen to me, but it would’ve the fan forever changing on me. Then I realized that my right scroll wheel was set to raise/lower fan speed and I was accidentally moving it. Duh! I changed the assignment and problem gone.
  13. TrevTremaine
    TrevTremaine Member
    Yeah, I thought about this, but I've several incidents happen without my hand touching the wheel at all. Oh, and by the way, it's still happening on 2018.4...
  14. Majariwr
    Majariwr Member
    Kennett Square, PA
    Maybe related, but for the past two days, the climate control seems to be turning itself on some time over night (and running down the battery). When I go to pre-heat the car in the morning, I find that the fan button on my iPhone app is on and the car is at 72 (also interesting is that the climate control in the car, and on the iPhone app is set to 68, so seems to be overshooting). Today I signed out of the app, closed it, restarted my iPhone, and signed back in. So we'll see what happens tomorrow.
    Could it be Vehicle Preconditioning? After two years of ownership, I've never actually detected this function to be doing anything. All of a sudden, is it now working to try to pre-heat the car in the morning?
  15. TrevTremaine
    TrevTremaine Member
    Possibly, but in my case, I've got pre-conditioning turned off. The temperature is still changing on it's own without any idea as to why it's happening.
  16. WannabeOwner
    WannabeOwner Active Member
    Suffolk, UK
    I have something similar, and have also not been able to put my finger on it. I've had it for a while though (some months at least).
    One common occurrence is stopping for Supercharge. Both wife and I get out, go and get a cuppa, and when we get back in the car the Climate is up on 26C or similar (having been left at say 21-22C). I have definitely not set Climate using APP in that situation. However, quite possible that Wife got to car first and her Fob change Profile from Me to Her (but she wouldn't have driven the car at 26C either, but it MIGHT have been set to her Profile when APP turned climate on,a nd since then car has been on my profile for the actual journey)
    Also notice it when we are setting off. Maybe we already used APP to pre-heat the car. Get into car, adjust temperature (e.g. down to 21-22C) and then it jumps back up again. Not sure of circumstances but could definitely be that I get back out to do something - e.g. open trunk to rearrange bags or put something else in - and then when i get back into the drivers seat temperature is back up at 26C
    I have wondered if it could be that setting Climate from APP is the cause ... i.e. that somehow causes the climate to be FORCED to a setting, again, a bit later on in the journey. I don't think it resets, by itself, whilst driving, only when Parked, but I wouldn't swear to it
