Yes, but I am not sure if that glued part would need to be changed if the internal cover and wiring (which are not glued) were to be replaced with a cabin camera version...
I am sure a retrofittable part would be designed with this in mind..?
That's exactly my point nr. 1. Tesla would have to design a retrofittable part for the S and X windshields respectively.
Thanks. So the assumption is that AP2 cars will get a free upgrade?
I'm going to post this as many times as necessary. Every HW2 car - no matter what options are purchased - was sold under the claim that it had the hardware on it. They can jack up the cost of post-order upgrades, of course. But if new hardware is needed, it goes to all HW2 cars. Tesla can't tie the hardware upgrade to the software activation. They are separate.AP2 cars that pay for EAP and FSD would be reasonable.
- So far we know that it's going to be dual gpgpu
Do you still think that is true even when Tesla is now saying “The internal name HW 2.5 is an overstatement, and instead it should be called something more like HW 2.1. This hardware set has some added computing and wiring redundancy, which very slightly improves reliability, but it does not have an additional Pascal GPU.”
Lol. I don't need a reason other than it was an advertised capability of the car. They have to give you wheels even if you never want to drive it.OK - you are going to insist on hardware you are not going to activate because.....?
It just seems like he articulates better reasons because you have no ****ing clue.My five year old can articulate better reasons for asking for things.
No one is busting Bill Gates for saying 640k memory ought to be enough for everybody today.
Those two things aren't the same, but cool, bro. IL. Tschuss.No clue about what? How to defend wanting hardware and wasting everyone's time on something that has no value?
If you didn't pay for FSD, there is no tort. Or you could pay for FSD and if that camera isn't needed - there is no tort.
Yes, I still think there's dual gpu setup. Adding just the arm cores makes no sense.Do you still think that is true even when Tesla is now saying “The internal name HW 2.5 is an overstatement, and instead it should be called something more like HW 2.1. This hardware set has some added computing and wiring redundancy, which very slightly improves reliability, but it does not have an additional Pascal GPU.”
Heh I completely agree with your sentiment. I said the same earlier — I can't possibly believe the motivation for adding those ARM cores alone without adding an additional GPU. Maybe it buys you a little bit of hardware failure redundancy to do some sort of basic pull-over-safely maneuver, but why bother coding that up when you can just shove in a second identical board for failover?Yes, I still think there's dual gpu setup. Adding just the arm cores makes no sense.
I don't know if the spokeperson was just misinformed or if the dual px2 setup is considered to be one gpu still in their eyes or whatever.
Does not buy you that.Maybe it buys you a little bit of hardware failure redundancy to do some sort of basic pull-over-safely maneuver
You see, the cameras are processed by neural net on GPU attached to the primary node (I somehow doubt they'd do dualhomed pci-e setup as they won't need gige to communicate the nodes then).
This means if the primary arm node dies/panics/whatever, the second node is blind, how are you going to pull over without seeing anything, you can just stop in place (i.e. as fast as you can), that's about it, but you don't need another node to just apply brakes superhard, gateway could do that on loss of contact with the ap node.
