HW2.5 capabilities
xspace
77
31
Ontario
Hi everybody. How are those of you capturing event trigger images doing it? Are you monitoring the wifi signals, then parsing them out? Are they not encrypted?
I searched through this thread, as well as on the internet, but couldn’t find the answer.
Thank you!
Reactions: CaliMS
ABC2D
993
1,058
Home
Thank you!
The car is rooted
brkaus
7,633
6,163
Austin, TX
I just went to the url:80, and the following was the response:
AccessDeniedAccess DeniedC643992D36F8F997QGMiuK4MIh7
Either pilot error on my part, or they’re now preventing access?
I believe the way you see the file is to
Intercept it at your home firewall as it is getting sent up. Need some sort of transparent proxy at the firewall.
Reactions: xspace
Padelford
391
361
Seattle
Ok, so now that I know the snapshots for my car stopped because the time for them was limited to just 23 hours, I rolled the time back and drove around some more.
Only managed to trigger a few slope up/down. The confusing part is oftentimes slope up would have a slope down in it too so I am not sure how NN decided if it's a slope up or down it's facing (because it's both).
From some experience, I’ve found that AP 2.0 doesn’t handle ascending or descending roadway well, especially if the roadway turns right or left. I’m glad someone else sees this as well.
Reactions: daktari
brkaus
7,633
6,163
Austin, TX
Definitely! Rolling hills with turns. Not even big hills. I was glad that verygreen found triggers for hills. Hopefully some day it will work well.
Reactions: daktari
daktari
747
897
Norway
Is it possible that the snap-shot is taken if there is disagreement between the vision system and the map?
Could also be that sensitivity is way to low, meaning false negatives.
Also glad they have a slope up/down trigger, I think my car is tricked to believe even the slightest slope is a bend. Low specificity probably because of lack of 3D perception.
BigD0g
2,019
4,385
Somewhere
Well if you think about it on a upward hill with a left or right turn, the car has no clue, since it can’t find the lane lines with the cameras facing the sky, they don’t pivot down like our eyes. This won’t get solved until they are leveraging the HD maps I suspect.
Reactions: croman
ChrML
700
962
Norway
Even if you know where the road is, you can't drive without seeing where you go. EAP might, but FSD can't.
HD maps might help by giving info that increases safety causing the car to drive more safely than a driver would by using the what he sees. But it should not decrease safety by driving into an area that can't be verified by the car's sensors.
xspace
77
31
Ontario
Question about AP2.0. Does anybody else find that in both TACC and AutoSteering, the car will maintain full speed as it approaches a stopped car ahead of it, until pretty hard braking is required? In this game of chicken, I nearly always hit the brakes before the Tesla does. This is bad for regen as well, as it requires significant brakes.
brkaus
7,633
6,163
Austin, TX
I see it on shallow enough slopes (or upward slopes) and turns where I assumed the road road is still visible. ESP where there is some side to side tilt change too. I think it’s hard to understand in monocular vision.
Reactions: daktari
brkaus
7,633
6,163
Austin, TX
Yes. All the time if the cars are fully stopped. Don't count on it stopping every time either, I've read of cases where it didn't stop. Someone posted on a Texas Tesla email list just this week about an accident. From the sounds of it, totaled the car.
BigD0g
2,019
4,385
Somewhere
Yah, that's the untracked car problem, the car doesn't "see" the car sometimes if it's not moving and didn't see it beforehand moving. Never ever trust the car to stop unless, your behind a moving car and even then be very wary around stop / go traffic especially local traffic.
DOCAL
459
804
San Jose, CA
I've noticed it on AP1 on some very shallow slopes. I had always assumed that it was treating either the left or right line as a primary reference, and so the apparent curve was throwing it off.
Reactions: daktari
BeesKnees
154
161
Oregon
My conclusion as well. I see the IC flash a sharp turn in the road. Exactly what you’d expect if it lost one edge, or prioritized one, on crest or dip. At least what we’d expect if there is no depth data.
I’ve been watching for edge drop out but one wants to be driving at these moments : ) so I don’t know.
