  • The TMC Podcast team will be live streaming a Tesla AI Day watch party this Friday at 4:30PM PDT. Check out this podcast clip for more details. You can watch the stream on YouTube.
HW3 upgrade or MCU1 death. Which will happen first?
Galve2000
1,044
377
NYC
After reading this I feel like the extended warrantee I got is just money in Tesla's pocket.. then again, I believe in the company and I did pretty well from their stock in the early days.. so I don't feel so bad.
but yes.. coverage for possible MCU1 failure was my main reason for getting the extended warrantee.. but i'm WAY under miles.. so who knows if it will ever happen...
Reactions: David29
viper2ko
1,564
1,656
If im not mistaken. If you pay out of warranty to fix a MCU it is then covered by 4 years warranty
Reactions: croman
KyleDay
1,509
3,432
AZ
You're all right and you don't know it. Yes, Tesla has done some limited ape3 retrofits, but ONLY on S/X MCU2/APE2.5 cars.
To date, I'm not aware of any MCU1 car retrofits (Neither APE 2.0 nor 2.5). I'm still wondering if APE2.0 will actually get a retrofit, although Elon has been clear that it will. We shall see.
KyleDay
1,509
3,432
AZ
Why can't rear camera record for sentry mode on MCU1 then?
Rear camera recording is indeed offloaded to mcu2 for the dashcam process. That is independent from FSD functionality which is wholly contained within the APE computer. The only autopilot/FSD content that MCU touches is that it contains the ADAS maps that autopilot uses for NoA navigation, but that's very minor and the same between MCU1/2.
Short story is I don't expect any MCU retrofits (for free, at least) as part of the FSD ape3 retrofit process.
My car(MCU1) always had issues with rear camera. It shows frozen image from past/different location. SC had replaced camera, even MCU with no resolution. Now with release of smart summon feature, when car do not get correct feed from the camera it take wrong decision. One time it almost backed into the wall, and another time it did not see the pedestrians. SC and AP engineers confirmed this issue after extensive tests now advised me not to use the smart summon.
Reactions: Cheburashka
IMHO tesla will have to update MCU1 too for FSD option. MCU1 don't have enough hp to process rear camera input required for FSD processing. I may be wrong.
Wrong. All FSD based processing occurs with the FSD computer. That’s why if your on AP2/2.5 and you pre purchased FSD Software you will eventually get FSD Computer upgrade for free.
As it relates to MCU/2, Elon said it’s coming and it it coming. But it’s a $$$ upgrade that will be optional. If you want to spend money on it then you can upgrade. It’s NOT a warranty item.
