Liquid hydrogen may be possible as an aviation fuel, but the energy density is still not great. Kerosene has around 10.5 kWh per liter, while liquid hydrogen has around 2.35 kWh per liter. That means that with liquid hydrogen, the fuel tanks need to have a volume that's over four times bigger for the same amount of energy. With a larger aircraft, more mass is added to the structure and the air resistance increases. On top of that, you can fill kerosene into pretty much any structural cavity, without much fuss. With liquid hydrogen, you need a lot of insulation, and you need to be pretty careful in how you design the aircraft to avoid temperature differentials. Large temperature variations can cause metal fatigue over time. To have the least amount of insulation relative to storage volume, spherical or cylindrical tanks are best. (Though you can have other shapes, at the cost of added insulation.)
Another consideration is that while kerosene is relatively inflammable, hydrogen is both quite easily ignited *and* it can detonate quite easily. The safety considerations alone can stop hydrogen-powered passenger aircraft from becoming a reality for years or even decades.
Yes, energy/volume and heat insulation are problems for H2. Efficiency of fuel cell and electric trusters would help, but not remove problem. Kerosene fire in airplane almost always kills everyone, so H2 cannot be not much worse. Small H2 leak in open space is not so bad, because it goes up fast. Large leak could deep freeze before baking...
Since Skylon (
I don't believe in bio fuels. Production requires too much land area. We don't have it. Batteries are probably never good enough for long distance flight. Not very many clean options left.
What about Lilium style plane docket into H2 fuel cell carrier plane? Passenger section could separate and land in case of trouble.
