Curious George
Bloomberg says, cost to produce hydrogen will plunge to $1.40 a kg by 2030 and to $0.80 a kg by 2050 due to renewables. So there is some hope for hydrogen.
Bloomberg - Are you a robot?
Just two words and I already know that whatever is after that is nothing more than some thoughts.Bloomberg says,
So 80% of that is used to refine petroleum today, which is used in ICE cars.
If ICE cars aren't there, then that 8 B kg/yr will be unused?
A mid-size FCEV at 60 miles per kg consumes 200kg/yr for 12000 miles/yr average US driving.
So, that spare 8B kg/yr is enough for 40 million cars driving 12k miles/yr? What am I missing?
The fact that this thread has been debunking the same hydrogen arguments for over 10 years now. You can't bring up any point which we haven't fully debunked over and over again.What am I missing?
Let take all that money spent on NG and H2 and produce more batteries.Do I need to remind you guys about the insufficient battery production capacity again?
That and the energy density what drives the H2 research.
Tesla might get into the mining business to secure minerals for electric batteries – TechCrunch
There is a difference between production issues and technical issues. The one is just a matter of scale if the numbers work. The other requires solving of problems that may be insurmountable.Do I need to remind you guys about the insufficient battery production capacity again?
That argument is bogus. There is far more actual battery production capacity than either H2 production capacity or fuel cell production capacity. It continues to increase to meet demand.Do I need to remind you guys about the insufficient battery production capacity again?
So if you have turned the surplus renewables into hydrogen, it might be more sensible to do something different - like turning it back into electricity on the grid, or using it to make synthetic liquid fuels, or all sorts of other possibilities rather than putting it in cars.
- Pressurizing up to 700bar to fuel cars which need very high pressure to support fast fill times and tank sizes which fit in a reasonable size car. This is significant extra energy, needed at the time of doing the filling (current systems use >10kWh electricity for 1kg hydrogen, which will drive a typical HFCV 60-odd miles, so the 'incidental' electricity would drive a BEV 30 miles on its own! The theoretical minimum possible energy with a 100% efficient compressor would be about 2.5kWh/kg, so any practical system is going to be worse than that)
Oh Wow. So for 10 year you folks are stuck in this thread? I've got some respect for you guys! We may need to wait another 10 years.The fact that this thread has been debunking the same hydrogen arguments for over 10 years now. You can't bring up any point which we haven't fully debunked over and over again.
BEVs need more raw materials and/or use less per kWh. FCVs need to change the laws of thermodynamics. Which do you think is more likely to occur?![]()
If the most efficient solution doesn't cover the demand due to supply issues, the efficiency of the second best solution is irrelevant as long as the price is reasonable. So not sure what laws need to be changed.
The law of conservation of energy. Why spend energy cutting the C off CH4 to burn H2 when you can just burn less CH4 directly? FCVs make no sense thermodynamically until we have a surplus supply of H2 which is going to be a while since we need ~10B kg/yr for industrial use.
BEVs make sense because it's more efficient to use CH4 to make electricity to charge a battery to drive a car plus it's more efficient to use wind or solar directly instead of losing ~half to split water; The amount of energy required to split water is far too high for the amount of wind and solar we have installed. Makes more sense to displace other fools fuel generation. So you need to use surplus wind and solar (wind or solar that would be curtailed if not used) of which we also do not have enough of....
Bottom line is FCVs won't make any sense for at least another 10 years.... probably longer.
I agree that this is not the near future and H2 makes sense only if zero emission is enforced.
This is an existing plant on the drawing. If they store H2 or CH4 depends on the end users.
