JohnSnowNW
...but you don't find the Nikola Truck's 800-1200 mile range dubious?
Even more so.
A
After actually reading the linked article, I realize that they are targeting their project on transportation from seaports, so mostly short haul to warehouses for aggregation or transshipment.
This would alleviate the heavy particulates pollution from a heavy concentration of diesel trucks that presently plagues areas near seaports.
To be fair, they're not really comparable. Toyota's truck has 40 kg of compressed hydrogen. Including the hydrogen tanks, that's likely something like 800 kg.
Nikola's truck uses liquid hydrogen, which means the tanks don't need to weigh as much, as the tanks don't need to contain a meaningful pressure. Maybe they could fit in 200 kg of hydrogen for the same 800 kg total. That would increase range by a factor of five.
I don't think the range for this vehicle is very unrealistic. 40 kg of hydrogen would mean around 800 kWh on the output of the fuel cell. I've previously calculated a need for around 1000 kWh for cruising 270 miles at 62 mph with a 37 ton semi. That's in perfect weather, though.
Yes, that's what they say. On paper it will work, even if I don't think Nikola will deliver a single vehicle.Liquid Hydrogen???
RT
Not to mention the wasted energy compressing, cooling then reheating the H2BMW's liquid H2 engine uses a large tank kept at cryo temperatures by maintaining its insulation at a high vacuum. Still, it must vent hydrogen to keep pressure down when not in use, and in 10 days of non-use loses all its H2.
That's some vampire drain!
temp of liquid Hydrogen, -423 F, (and it can combust, obviously, and is way more dangerous) temp of liquid Nitrogen -321 F.BMW's liquid H2 engine uses a large tank kept at cryo temperatures by maintaining its insulation at a high vacuum. Still, it must vent hydrogen to keep pressure down when not in use, and in 10 days of non-use loses all its H2.
you could, and can, casually walk down the halls at NIH, building 10, and other buildings and research labs, past numerous ~5ft high, ~2ft diameter tanks of LN (liquid Nitrogen) without too much thought, and truck loads of tanks are delivered daily. (Ultra freezers kept at -180 or so F)
OTOH, I would be extremely leery about tanks of LH anywhere within 1/2 mile of anywhere I was, especially in enclosed spaces, would refuse to enter the building.
The chemistry labs at Virginia Tech in Blacksburg, Virginia, USA, ha d no floors above the labs so any explosions did not pancake above floors. 52,000 LP (natural gas) bottles blew up one night in a chain reaction series of fires and explosions in Florida last summer. spectacular expolsions "just happen"
You cannot casually fool around with "Liquid Hydrogen" without amazing pressurized fireballs
(try driving a camper with a 20 pound LP gas bottle through a tunnel without being arrested. much less a cryo tank)
The main page says:According to Nikola, it's merely compressed Hydrogen, not liquid.
Nikola Motor Company | Premium Electric Vehicles
ZERO EMISSION
HYDROGEN STATIONS
Free* hydrogen fuel for up to 1,000,000 miles. Zero emissions, from production to consumption, and still up to 1,200 miles between fill ups.
Nikola™ plans to install solar farms to create hydrogen from electrolysis. Nikola™ will convert solar energy to hydrogen using only energy and water, making it the only fuel that is zero emission from production to consumption. The hydrogen is stored at Nikola™ stations in liquid form, and then dispensed into vehicles as compressed or liquid hydrogen. When produced this way, the entire process--from energy creation to energy consumption--is 100% emissions free with Nikola™.
All the more reason to go 100% electric, not to mention the inherit energy efficiency issues with hydrogen.
It's just so easy to plug in or even better, charge my EV wirelessly using something like Plugless Power.
I believe liquid hydrogen is a lot safer than compressed hydrogen. Just like with gasoline, the hydrogen would need to evaporate and mix with air before you have a flammable/explosive mix. If you shoot a hole in a liquid hydrogen tank, hydrogen will pour out, pool on the floor, evaporate, mix with air and burn. If you shoot a hole in a compressed hydrogen tank, a massive jet of hydrogen will stand out of the tank. The noise alone will be enough to rupture your ear drums, but that's just the start. If you're lucky, it ignites right away, and the jet of gas turns into a column of flame, while if you're unlucky, it doesn't ignite right away, mixing with air before the slightest spark sets off a massive explosion.You cannot casually fool around with "Liquid Hydrogen" without amazing pressurized fireballs
I don't think there is any question about it.the question remains whether it's more efficient and convenient to turn it into hydrogen, or just transmit and use it as electricity.
A
Burning H2 in an internal (or external!) combustion engine is an entirely different matter: trading pollution for reduced range and increased explosion hazard might have some benefits in pollution-plagued areas. But electrified rail might be better yet.
I only said it made sense for a relatively short 200 mi range vehicle to operate locally around the seaports.But that's also a perfect use for Tesla's EV semis. I don't see that hydrogen has an advantage.
The main page says:
I know I've read on their site that the Nikola One would use liquid hydrogen, but maybe they've changed their minds. 200 kg of hydrgen stored at 700 bar would require tanks weighing around 4 metric tons, though.
