Hydrophobic glass treatment
Discussion in 'Model S: Interior & Exterior' started by vetboy45, Mar 6, 2013.
  1. vetboy45
    vetboy45 Member
    Kent wa
    Is it ok to use hydrophobic glass treatments on the windows (and the panoramic roof)? I believe they are coated with something else to prevent heating of the interior by the sun and don't want to mess that up. Thanks
  2. Beavis
    Beavis Model S Signature 991
    Colorful Colorado
    What the heck is a "hydrophobic glass treatment?" Sounds like you're talking about a treatment to shed water, like Rain X? If that's what it is, I use it on mine and it works for me.
  3. cloroxbb
    cloroxbb Member
    Im hoping "Neverwet" comes to market before I get my Tesla so I can use it on the windows. It works better than Rain X
    www.neverwet.com
  4. vcor
    vcor Member
    There is a metalic coating in-between the two layers of glass to reduce heating/cooling through the window. Many cars use the same process. It's not on the outside of the glass and it's safe to use things like Rain-x or Aquapel.
  5. vetboy45
    vetboy45 Member
    Kent wa
    Thanks. Sorry about the terminology Beavis. Too many years speaking science. I doubted there would be a problem (obviously Rain-X etc would be fine) but some of the newer semi-permanent treatments made me wonder.
  6. bonnie
    bonnie Oil is for sissies.
    Columbia River Gorge
    Who cares about windshields - I want it for my solar panel installation! Solar panels coated with neverwet would be huge - I literally see my production increase by about 10% after weekly cleaning of pollen/dust.
  7. pete8314
    pete8314 Vendor
    DFW
    I used Aquapel on my screen, no issues.
  8. Lyon
    Lyon 2016 S P100DL, 2016 X P90D
    Eugene, Oregon
    I've got Aquapel on all the glass. It makes more difference on the front window than on all the others. At freeway speeds windshield wipers are only necessary in heavy rain or when following a semi-truck or something.
  9. dadaleus
    dadaleus 4GETOIL P85#S70,FdrX,S85D
    Solana Beach, California, United States
    Was about to apply RainX. Now I want this Neverwet stuff, but their site makes no mention of it coming to market.
  10. AMPd
    AMPd Active Member
    Northern California
    That neverwet stuff looks amazing.
    I really hope it makes its way to production ASAP
  11. artsci
    artsci Sponsor
    Timonium, Maryland
    Agree, it looks like it's a whole level better than RainX.
  12. Al Sherman
    Al Sherman It's about THIS car.
    Batesville, IN
    Is Aquapel better than Rain-X?
  13. gsxrex
    gsxrex Member
    NorCal
    I believe the claim is that Aquapel lasts longer than Rain-X. I've never tried Aquapel, but have used Rain-X a lot in the past. I did put Aquapel on the Model S a few days back. Sorry, can't give you any more insight than that as it hasn't rained yet. :)
    I will say that if you do Aquapel, one application of the little squeegee thing is good for both the front and back glass, but you have to go fast. Instructions say to work in small sections, don't let it dry, and use a paper towel to wipe it off. I found that the all the paper towel did was smear everything around. So my recommendation would be to apply to both front and back, use the paper towel if you want to get any excess that hasn't dried, then use a microfiber towel to get it off. The microfiber towel cleaned up the glass quickly and nicely.
    On a related note, I found the Aquapel glass cleaner works better than Invisible Shield to clean the windows.
  14. vetboy45
    vetboy45 Member
    Kent wa
    Anyone have any experience with Nanoskin Rain Plus?
  15. agentsmith1612
    Germany
  16. ChadS
    ChadS Petroleum is for sissies
    #16 ChadS, Mar 7, 2013
    About 10 weeks ago I put Aquapel on half of my windshield, and "G Glass Rain Repellent" ("totally green" "ultimate biodegradable" "grown and made in the USA") on the other half.
    So far, I like the G Glass. In addition to the "green" claims (which I have not yet made any effort to verify) it was cheaper and easier to apply. However, from online comments, it supposedly doesn't last as long. So far it still seems to be working as well as the Aquapel, though. Both definitely help keep the screen clean, but neither has any chance of negating the need for windshield wipers.
    UPDATE Mar 9: I just washed the car, and when I spray water on the windshield, the Aquapel side beads up as the water hits it, whereas the G Glass side sheets - the difference is striking. But when I stop spraying and let it sit for a while, they look awfully similar.
    UPDATE Sep 16: Same thing - while spraying water on the glass, G Glass side sheets, and the Aquapel side beads. But stop dumping water on it for 10 seconds, and the two sides look identical. I have not re-applied anything.
    Both sides did require a bit of rubbing with a paper towel to get the haze off; perhaps that was made worse by low temperatures at the time I applied it. I will try a microfiber towel next time.
  17. FlasherZ
    It should not be used on cars.
    Ultra-ever dry is an awesome product for coating things like shoes, gloves, and other surfaces... unfortunately, it's not completely transparent yet. It leaves a white translucent coating, as the review below also notes.
    Ultra Ever Dry Review - Does it Do What It Advertises?
  18. agentsmith1612
    Germany
    Thanks for your advise.
    If it's no 100% transperant we should not use it on cars. In the video we can see that the shoes have another color with the coating.
    Here in Germany there are a lot of companies that sell an "nano coating". But they do the job for you. You bring your car an they will coat it, because at home you can not make that.
    I have not such a coating on my car. Other users reported that this last only a half or one year, as well.
  19. FlasherZ
    Correct. It is just a coating, bound to the surface. Abrasion causes it to weaken. If you apply it to a jacket or some other piece of clothing, it will come off after a few cycles in the clothes washer.
  20. shokunin
    shokunin P85 & M3
    Irvine, CA
    A coating for windshields is a lot more difficult since it has to be transparent, ability to be abraded by windshield wipers constantly and have no glare/hazing/odd reflections that might interfere with visibility. Lots of new coatings coming to market. The neverwet looks amazing, I'm sure there's a lot of uses where that could save tons of money on washing industrial equipment and aircraft, wonder how it does with graffiti.
