Anyone else feel like mundane details like baggage and security could use some more attention?
As a consumer, my problem with getting to LA has nothing to do with the one hour travel time in the air, and everything to do with the way one hour of flight time takes over four hours of real time.
Some of the wasted time is getting to the station and getting from the station to your destination. I'm not really sure how to avoid that. I think hyperloop is likely to make the problem worse if it has fewer stations. (There are lots of airports in the Bay Area and in the LA area).
Some of the wasted time is adding in a safety buffer so that if I get stuck in traffic, I don't miss my flight. If hyperloop were to operate more like a subway where you just get on the next car, you could nix this safety buffer. but if seating is limited and the operator tries to fill every car, then you'd be required to arrive for your reserved car, and you'd need that safety buffer.
A lot of the wasted time is security. The proposal makes short mention of that saying that it would be similar to airport TSA screening. only airport TSA screening is terrible. The proposal seems to imply that with regular departures there wouldn't be much of a security problem. but airports have regular departures, and the lines are usually long. It seems like a simple problem to solve: add more screening capacity. Somehow airports don't seem to be doing that. Is there some technology that would allow screening to go faster? so far, it seems like we just keep making it slower (laptops out, then liquids out, then shoes off, now mm-wave machines that take 10X longer than metal detectors, etc.)
More wasted time is luggage handling. You need to be at the airport at least 30 minutes ahead of time for your luggage to get on the plane. It takes about 30 minutes from landing before you get your luggage. Does hyperloop have a solution to that?
An annoying amount of time wasted is just getting on and off of the stupid airplane. Hopefully this will be fixed by those huge doors that open wide open. (At SJC, they frequently bring stairs to the back of the airplane in addition to the jet bridge at the front. Why don't they always do that everywhere?) I hope anyone building hyperloop recognizes that while big doors are probably more expensive, they're important.
Anyway, for hyperloop to attract me as a consumer, the travel speed isn't important. Instead, I'll be comparing the total time which includes security, luggage, safety buffer, etc.
