So, how do the Powerwalls deal with the generator and solar as they approach full charge? Or do you preemptively shut the generator down as the charge level gets high.
Just curious.
All the best,
BG
I haven’t tested all scenarios, but the in “normal” use the generator is tied to a transfer switch that senses when grid power is down. Before the PW were installed that was set to auto, now I have it set to manual.
I have tested when the batteries were off, near empty, and charging from solar. The generator adjusts output and the batteries don’t do much in those tests because the generator meets the load of the house. I don’t really see running in this scenario, the generator was here before the PWs and I would only use it if we were off grid and the PV/PW didn’t have enough such as a winter multi-day storm outage. We are in an area that gets serious winter storms.
I guess the answer to your question is I haven’t tested the scenario with PWs near full, but I don’t see that being a use case where I would manually turn the generator transfer switch on.
So the OP could hook up DIY batteries through a manual transfer switch to backup panel of a PW install. Wouldn’t be hands off and seamless, but it would work.
