So I went and plugged my car in to the charger I last used when the charging packed up on me. It failed on my again with a #981
I drove home slowly on range mode and lo and behold, same issue. I’m in panic mode at this point. But wait, a year of researching I remember to actually look at the screen. It’s climbing to 54v the. Shutting down. Try my 120v cable and the same. Try the Tesla UMC with both 240 and 110v reduced to 12A. Why not try my open EVSE. Same every time. In a worrying 10 minutes I check the fuses in the PEM. And one shows no continuity. I make a solid link to bypass the fuse. I know it’s there for a reason, but it’s on the charger side and I’m looking at this.
Thankfully it charging again. I have to look up where the fuses can be obtained. I’m sure someone found a cheap supply so I’ll get it juiced up and pull the plug until a replacement can be found.
Just thought I’d share.
