do you have a link to a good guide on how to remove the center console?
Center console removal - Tesla Owners Online
that thread has a ton of info on how to remove it. it's INSANELY easy. literally a few bolts and maybe screws (not all models have them, apparently), and disconnecting two harnesses, and the entire thing just slides right out.
the hardest part is getting the trim panels off. once you have the carpeted side panels and plastic dash panels off it's crazy how easy it is.
Anyone try this yet?
US $59.00 | For Tesla MODEL 3 dual 10W mobile phone wireless charger, fast charging QI standard center console armrest box
US $59.0 |For Tesla MODEL 3 dual 10W mobile phone wireless charger, fast charging QI standard center console armrest box|Cigarette Lighter| - AliExpress
The center console contains the security module. The proper method for disconnecting the center console involves disconnecting the 12V battery and the HV control circuit under the left rear seat.I am looking at the instructions.
I still can't figure out why is necessary to remove the Rear Underhood Apron? That under the frunk.
Could you skip disconnecting the power? You could make that choice, but there is a risk.
Exactly. That's why my instructions follow Tesla's instructions. Do as I say, not as I do *wink wink*I did not disconnect. I Powered Off fully, but car kept coming back online. Without security module, could not drive when console was out, but everything worked.
As always, my suggestions are opinions and I am not liable for any issues that occur.
Correct.I see. I am guessing just removing the center console as a whole should be enough to drill and install the 12v outlet? No need to take out the inner part?
To date, no iPhone can charge faster than 10 watts via wireless.The new(er) variety are up to 15 watts with adequate power supply
lots of us have pulled the console without disconnecting the battery and the penthouse without any issues...what's the potential risk involved from pulling it without doing those?
Yes! In fact, the new Tesla charging pad only uses one USB-C connector to power the whole pad. It appears to be fast charging, but to be honest, if I want fast charging I just plug directly into USB-C. 50% charge in 30 minutes! Which sounds good, but my Tesla supercharges faster than that! ;-}Cool. I was just confused cause Tesla instructions said to remove rear seat cushions & and apron but didn't say what for. No indication on disconnecting the 12v - or maybe I missed it.
Anyways, does the upgraded USB-C port provide the necessary voltage & amparage for fast charging? I was thinking if i went this way, to use a USB hub to power both sides of the charging pad.
For exampleWhen i google 1111072-00-E
