There is a fault light on in the speedometer. Could there be a chance the battery is disconnected? And if so, where would I find the disconnect. Thank you for the help, I really appreciate it.
Click on the fault on the VDS when you are in service mode. It will tell you what the fault is.
If I remember correctly, when the traction battery is disconnected (by pulling the service disconnect in front of the driver rear tire) you would not have power to anything, including the VDS (but I could be wrong). If the APS was disabled (via the service menu) then you would get that message when you "woke" the car.
Frankly, I'm surprised you still have any power after 4-6 months at zero for the traction battery. I assumed the 12v would wear down in that time.
As I mentioned, download your logs (I sent you the link) and take a look. Also, reach out to Gruber.
Good luck.
