I cannot access central control screen pad while sitting in passenger seat and charging
Discussion in 'Model 3: User Interface' started by coolmanfever, Dec 27, 2019.
  1. coolmanfever
    coolmanfever Member
    toronto
    The central control screen keep showing car is charging while I sit in the passenger side of car. Every touch on the control pad, nothing changes. But when I open the passenger car, I am able touch and access central control screen pad again. But when I close the passenger car and sitting there, I cannot access again and show charging window. The screen just keep showing charging screen. Is this by design or software problem that my car has? thanks
  2. rincewind
    rincewind Member
    London England
    Mine does exactly the same. I just make sure I'm in the drivers side, then it works.
  3. Watts_Up
    Watts_Up Active Member
    In a galaxy far, far away
    Can you try to buckle the driver seat, before seating inside.
    Seat on the driver seat and press on the barke pedal, and exit the car and close the door.
    I did this to keep the car in Neutral. I cannot test about the driver seat right now
    but this might be a possibility for keeping the central screen alive.
  4. webbah
    webbah Member
    Lucerne, Switzerland
    I haven’t tried it, but you might be able to just enable the new “camp” mode for the HVAC which keeps everything on.
  5. Watts_Up
    Otherwise, just moving from the driver seat to the passenger seat by passing over the central arm rest without opening the driver door works.
  6. coolmanfever
    coolmanfever Member
    toronto
    thanks. I guess this is normal.
  7. SMAlset
    SMAlset Well-Known Member
    SF Bay Area
    It's probably done so only the driver really has control of certain aspects of the car. Sometimes people have their kids (out of car seats) sitting in the front with them and wouldn't want them changing up things. But I've been in my passenger seat when my husband drove my car and ran in to get something at a store and found I was locked out of doing some things even if I had my phone key and card key on me.
  8. Docma
    Docma New Member
    Zurich
    If you sit in the passenger seat with al the doors closed, just push down hard on the driver seat cushion to activate the pressure sensor.
    This worked for me
