I decided to splurge a little
Discussion in 'Model S' started by Sir Guacamolaf, May 18, 2017.
Tags:
  1. Sir Guacamolaf
    Sir Guacamolaf The good kind of fat
    My Model S
    Hey you live only once! What do you think?
    • Funny x 2
  2. Sir Guacamolaf
    My Model S
    In case you missed it, look at the valve stem
  3. Max*
    Max* Charging
    NoVa
    How long did it take you to get the angle just right to have the T from the caliper line up between the spokes? :p
  4. timvracer
    timvracer Member
    Los Gatos, CA
    The T is not centered... try again.
    • Funny x 2
  5. Sir Guacamolaf
    My Model S
    4 wheels .. got lucky with one ;-)
  6. GlmnAlyAirCar
    GlmnAlyAirCar Member
    Southeast PA
    I hope you're using only made-in-America air in those times!
  7. Jeeps17
    Jeeps17 Cath Jockey in a P85
    Montreal, Canada
    As a fiscally responsible individual I can't stand show-offs like you that spend money on flashy bling-bling.
    And to put said bling on a "green for the rich" glorified golf cart ...
    For shame !
    :D
    • Funny x 3
  8. pilotSteve
    pilotSteve Active Member
    Vancouver WA
    which firmware version did you get today :) ?
  9. BluestarE3
    BluestarE3 Active Member
    Norcal
    On the other hand, if You Only Live Twice, something like this may be more apropos:
    • Funny x 3
  10. McRat
    McRat Well-Known Member
    LA
    A friend replaced the bolts in the engine compartment of his hotrod with anodized parts that had an emblem on them. About 50-100 fasteners.
    He lined up each emblem horizontally, by using different thicknesses of washers so when the bolt was torqued, it lined up perfectly. The same was true for each visible fastener of any kind, anywhere on the car you could see them.
    He was nuts, or is that bolts?
    Anyways, there is a dot on the tire that you should line up with the valve stem so the balancing takes less weight. They missed it appears.
  11. Canuck
    Canuck Well-Known Member
    South Surrey, BC
    I've heard Trump has the ones with the Russian flag in them.
    • Funny x 5
    • Disagree x 1
  12. whttiger25
    whttiger25 Member
    Oakland, CA
    3 funny/love, 1 disagree. Sounds like this forum is tracking closely to Trump's current approval rating
  13. McRat
    LA
    I'm thinking 1 disagree is from a person that knows Donnie has a Tesla.
