I finally found a way to secure the floor mats
Discussion in 'Model S: Interior & Exterior' started by mep, Oct 16, 2013.
  1. mep
    mep Member
    Chicago
    #1 mep, Oct 16, 2013
    I have been reading the threads on fixes for the moving and flapping floor mats but did not find anything that I thought would work for me. I looked at some of the aftermarket floor mats folks recommended and while they seem to be of better quality and come in different colors I also read that they would still move around and the passenger mat still flaps when hitting the accelerator in some peoples experience.
    I found a fix. You will need a pair of nail scissors and some sort of tool to pinch a hole into a carpet. In addition you will need these:
    http://www.ecstuning.com/ES348762/
    http://www.ecstuning.com/ES348755/
    I had them in a previous live when I was driving a VW Golf. These clips keep the floor mats in place, period.
    Here is how to install them. It took me about 20 min to prepare the floor mats and to install them in the car.
    1. Mark the spot you want to install the clip (use the lower part of the hole clip as a template) and cut off the little nipples adjacent to the hole.
    2. Cut out the hole. Cut about 3 mm outside the lines.
    3. Turn mat over and remove some of the shag surrounding the hole using the nail scissors.
    4. Insert the top and
    5. the bottom of the two piece assembly. I placed the mat onto the floor and stepped on it with my heel to make the assembly snap.
    6. Installation in the car: Use a sharp tool to pinch a hole into the carpet below the floor mat. This is easy next to the doors, more difficult closer to the center console. There make sure to use the tool to lift up the carpet to make it easier to screw in the screws.
    7. Once screwed in, place floor mat on top and fasten by turning the clip 90 degrees. The floor mat will now be secured.
    8. We have all seen it. This is what the passenger floor mat looks like after hitting the accelerator. It flaps over and now sits on my passengers feet.
    9. I placed a floor mat screw right at the top of the mat. This will never fold over again. In addition, I placed two screws on the two corners of the driver side mat close to the drivers seat and the fourth screw on the passenger side just below the right edge of the seat. That should do it.
    Thanks VW/Audi for making the floor mat screws.
  2. jcaspar
    jcaspar Member
    Sacramento
    Very nice find! Thanks for sharing.
  3. tdelta1000
    tdelta1000 Active Member
    South Florida
    This is a VW product but still a great solution for The TMS.
  4. mep
    mep Member
    Chicago
    Yes it is. Here are more pictures of what the installed screws and the driver floor mat look like. It has been a week and the mats are nicely staying in place.
  5. brianman
    brianman Burrito Founder
    Perhaps a dumb question but I'll ask anyway. Does starching (like for shirts) work for floor mats to make them more willing/eager to hold shape (/stay down)?
  6. darthvdr
    darthvdr Member
    los gatos, ca
    Do the mats slide that much for you guys? I have experienced this problem yet
  7. brianman
    I don't have a sliding problem but I am getting the "limp" passenger side problem (with my Lloyd's) in the last few months.
  8. AmpedRealtor
    AmpedRealtor Well-Known Member
    Phoenix, AZ
    I have the stock Tesla floor mats that come with the car, circa late August. I do not have any movement, positioning, or flopping problems. What am I doing wrong? LOL
  9. brianman
    My Lloyd's didn't show any flopping for approximately 8 months.
  10. Discoducky
    Discoducky Happy owner of a P100D X and a brand new 2021 M3!
    Seattle
    Great post! I'll make the update once we switch back from all weather mats (which I love BTW as I have kids and we live in the beautiful Pacific Northwest ;))
  11. phat78boy
    phat78boy Member
    Phoenix, AZ
    You are definitely not flooring it from a stop enough then. ;)
    My passenger side flopped all the time, seemed to be worse when the weather was hotter. After complaining a couple times, more my wife then me, the service center finally added velcro. It works for now, but not what I would call a "fix".
  12. mep
    mep Member
    Chicago
    Hmmm, mine used to move around all the time. In fact, there was almost a step like structure forming underneath the accelerator. I had to do something. I also tried velcro but could not find a way of attaching it to the underside of the mats. I did not want to use any kind of adhesive tape because I assumed that this would cause a gluey mess eventually.
  13. aaronw
    aaronw Member
    United States
    In my case I gave up and replaced the front mats with the Lloyd's Luxe floor mats. They're much nicer than the Tesla mats and don't suffer from ED when I accelerate. The funny thing is that Tesla replaced my mats once and the new ones were worse than the old ones.
  14. AmpedRealtor
    Phoenix, AZ
    Yes, I drive like a grandpa.
  15. austinEV
    austinEV Supporting Member
    Austin
    So I followed these excellent instructions and now have a passenger mat that isn't flopping and a driver mat that isn't creeping up under the pedals.
    A few tips: There are little sharp points on the bottom half of the pair that go on the mat itself. They are meant to drive into some carpet material or something. I had to snip them off for the 2 halves to come together. Also cut the hole out a bit generous. The locking mechanism won't work if it is a snug fit.
    Also, there seems to be a lot more carpet padding on the door side than the console side. The screws that go into the car side go easily into the door side, but are too long for the console side. Either cut them down, or be ok with it tenting up the mat a bit.
  16. zwede
    zwede 2013 P85+
    Plano, TX
    Just wanted to thank OP for this excellent solution. Got my parts from ECStuning today and now I have a properly secured passenger mat.
  17. silentsnow31802
    Just did this today but I installed them on the bottoms of the mats. I had problems with the mats sliding up not flapping down. Worth noting I have the newer mats meant for the newer carpets with mat stays built in however I have an old enough car that it did not come with the stays.
    Thank you OP for this. Looks factory and gets the job done well.
  18. ATC@LWSK
    Skopje, Macedonia/Abu Dhabi, UAE
    Great solution, thanks OP for the idea.
