I made a cable hanger to charge from the middle of my garage.
F14Scott
198
311
Houston
I thought I'd share; I just put this together, this morning. About $75 in from the local hardware store, and two hours to string it up.
My wife parks on the right-hand side of the garage and likes to nose in, so now she can do that without schlepping cable to and from the HPWC.
Also, I'm considering the Mini SE, whose connector is on the car's starboard aft, so I'll be able to nose in on the left and share the HPWC (with this: Tesla to J1772 Adapter – EVSE Adapters ).
F14Scott
198
311
Houston
The chain support for the connector hook turned out to be not optimal: removing the connector with one hand was difficult. So, I replaced the chain with an aluminum bar, which works much better.
Reactions: f308gt4 and bons
neurocutie
330
158
upstate ny
nice... I just bent up a wire coat hanger :) works fine. Doesn't look like much is supporting that long cross piece though, so it can't be too strong or stable. My wire hanger comes off of the rails for my garage door. Your rails are high up cuz your garage ceiling is quite high...
Ficheh
73
41
SF
I use a retractable tool holder (like a heavy duty spring loaded key holder). Cost was under $20. Keeps the charger up high out of the way when not plugged in and there's no excess cable on the floor when it is plugged in.
Reactions: X-pilot and BEPA400
F14Scott
198
311
Houston
It's a double garage door, so I don't have a rail in the middle of my garage, hence my cantilever solution. My conduit arm is supported by a steel cable that can be adjusted with a turnbuckle.
Reactions: BEPA400
F14Scott
198
311
Houston
I thought of that, but I didn't like the idea of dragging the cable and retraction string across the tail of the car when plugging in.
