As far as I can tell you have a few costs that need correcting:
1) Delivery: cost of electricity is not just the generation cost of the electricity ($0.065), but you also need to include the variable costs of delivering the electricity to you (i.e. the electricity did not just get to you for free, for example there are transmission and distribution charges).
2) Charging efficiency: You calculate your weekly electricity costs as the kWh amount used in the car, but to get say X kWh of energy in the car what came out of the time of use meter (what you pay) is more than X kWh, there are charging losses.
3) Time of Use: Are you really going to be able to charge 100% of the time overnight at lowest costs? Depending on your driving pattern, I think you should minimum add a 10% fudge factor to at least account for: some charging off peak times, and needing to charge on the road. After all Tesla supercharger rates won't be free and will probably come in at around CAD$0.20/kWh. As I understand it Tesla does not actually charge per kWh, but at a rate per minute that is tiered depending on your charging rate.
So now some more gory details:
1) Delivery: Given your north of Toronto location, I presume you have similar costs to me in Toronto (Toronto Hydro), which even if you are not with Toronto Hydro would have been approved by the Ontario Energy Board. I know there are sunk costs that you already pay so it does not make sense to pro-rate those or include those as a cost for electric vehicles (eg. $27.69/30days customer charge that is buried in the delivery charge). However, delivery charge components that are specifically billed on a kWh basis should be included in your cost to drive a vehicle as those directly go up based on kWh consumption and are not sunk costs. There are a ridiculous number of charges that specifically apply to electricity consumption and are billed on kWh basis, including:
Transmission charge: $0.0133/kWh
Distribution charge: $0.01512/kWh
Anyhow, you probably need to add about $0.03/kWh as the "Delivery" charge on top of cost of electricity.
2) Charging efficiency: You can google this but people seem to be getting around 80% efficiency. i.e. If you pay your utility for 100 kWh, only 80 kWh will make it into the battery. So you need to increase kWh costs by 25% to add back the 20 kWh costs that you used when you drove with 80 kWh used in the battery.
I find that when you do the math on a high mpg ICE (eg Prius) vs say a Model 3, using the "true" kWh costs vs a high mpg gas car, the "fuel" savings are somewhat marginal. Certainly not enough to say that it financially makes sense to get a Model 3. However, if Model 3 does become full self driving like Elon Musk says it will, that is a different story. It greatly increases the utility of a Model 3.
