I opened my car without the key...
Galinette
256
230
Nantes
I’m on a vacation site and today I let the car at the destination charger at 300m from the lodge. After 2h30 I went back with the kids, and pressed a door handle which raised, and let me open the car. I locked the first kid in its seat, closed it’s door, and then, impossible to open any door, the car was locked. Looked for the key in my pocket, damn, no key. Fortunately i had my phone and could unlock and drive the car with the app. Back to the lodge, the key was in my drawer...
So, the car let me open a door, 300m from the key, 2h30 after having left the car.
Anyone experienced this???
Reactions: David29
Galinette
256
230
Nantes
That’s a possible explanation for the skeptical.
However:
If a door is not properly closed, the handles do not retract AFAIK.
The only possible suspect door is the rear left (where I seated the kid), because the car locked just after I closed it. When I initially went to the charger alone in the car, and it didn’t signal poorly closed doors. I did not touch that particular door when leaving.
What I may have done is forgetting to manually lock with the fob the first time, I just walked away. And for whatever reason, the car did not lock. 99.99% sure this is not a poorly closed door issue.
Is automatic locking when fob walking away handled by the MCU? My MCU is so stupidly random these days I suspect it. For instance, the other day, I had to reboot before being able to open windows.
drklain
1,043
1,049
Scottsdale, AZ/Fairfax, VA/Brussels, BE
Interesting theory. I'm honestly not sure what part of the car handles the lock/unlock but MCU is a ikely suspect. For what it's worth (and obviously doesn't address what happened), I travel about 3 weeks a month and my car spends a lot of time parked in an airport garage. When I walk away and to the terminal, I always look in the app to see if the car is locked (just for my piece of mind).
Reactions: David29
Alysashley79
1,194
512
Seattle(ish) WA
My kids have left a door not completely closed and the handles did in fact retract. If the door is wide open they stay open but if it’s sorta closed but not fully locked into place they will.
Reactions: SSedan
A-Wimoweh
358
177
Jungle
I've also discovered that my walk away lock switch gets turned off randomly sometimes. I suspect it happens during an update. Its not always obvious that the car is unlocked, especially since the handles will retract with the car unlocked. But fortunately most Tesla-less people don't know how to work the handles, and that provides some small measure of security.
Todd Burch
Voltage makes me tingle.
Nov 3, 2009
7,801
28,498
Smithfield, VA
You drove 300 mi from your key and didn’t see a single “key not inside” message on the dash?
If the key is not nearby when you go to start the car, it will not start.
If the key is nearby when you start but you later drive away from the key, you’ll get a message on the dash.
You didn’t get any indication of either of these messages?
Todd Burch
Nov 3, 2009
7,801
28,498
Smithfield, VA
He said 300 meters not miles. :) The destination charger was 300 meters from where he was staying.
Ok, I was misreading the whole situation. I saw the “m” but was thinking it was a typo/language barrier thing on the OP’s side.
Based on that I’d agree with the assessment that a door wasn’t fully-closed.
