RyanS
Ka-chow
Keep it on if you plan to keep your car beyond warranty period. Electronics don’t like extreme heats. Tesla electronics will cost you a lot of $$$.
I should see what a sun-shade and cracking the window would accomplish
could have been battery conditioning. A/C could have kicked on to keep the batteries cool. In my experience, leaving just the cabin fan running shouldn't have a large effect on battery drain. And looking at your chart, your overheat protection should have only kicked in 2x:
the first around 11:15am; the second around 2:30pm.
In the AM, cabin temp responds rapidly, while in the PM, cabin temp reduces slowly. This would imply the AM used A/C while the PM didn't. So.... just speculating here, but maybe if the A/C was running for conditioning the battery, the car was applying A/C to the cabin as well.
Some people are wondering if Tesla implemented it to protect the displays and electronics.
The car will not cool the battery using the AC when parked. Absolutely 100% positive about that. Same with cold temperatures. The car will not heat the battery when parked. Only if you turn on the climate control via the app the car might heat or cool the battery. For the active battery cooling to kick in the battery has to be at approximately 50 Celsius. That’s extremely high and does not happen in normal driving. But again it won’t do that when the car is just parked. Only during charging or driving.
You have a defective screen! Get it replaced before it gets worse. Cabin overheat is not for the electronics!This is exactly right. I was one of the few who had the phantom touch issue. It only happened when the inside of the car was over 130F when I got in. I haven't had an issue since cabin overheat protection was added. I shared detailed information with Tesla every time it happened so they were aware that in my case cabin overheat protection would fix the issue.
It's not a creature comfort either, it's a safety measure. 105° isn't what I would call comfortable.Tesla's cabin overheat protection is nothing more than a creature comfort item, it is not there to safeguard the car.
One has nothing to do with the other. You will probably get into a habit of putting the shade on and cracking the window, but the majority of cases of children being left in the car happen when it's not the normal routine.If you can remember to crack the window and put the sun shade on, you probably will remember to take the baby with you anyway.
For those claiming little to no loss with COHP turned on: are you sure it's running? Have you checked it throughout the day?
My car seems to go into a deep sleep during the day which prevents COHP from running until I open the app to check on the car.
Today I opened the app to see the interior at 124° and it started dropping immediately after opening the app and waking the car. (No AC mode selected, this was about 3 PM before the servers went down)
v 32.2
Try leaving your phone or iPad in hot car...it turns off.Some people are wondering if Tesla implemented it to protect the displays and electronics.
Agreed. I'm in SW Florida (also known as "Hotternell") and I might see 3 or 4 miles lost for the 8 hours I'm at the office.Dunno man. I have it active on mine with it being waaaaay hotter here and don't see your losses.
Very informative post. Thank you very much!we really need to stop the speculation that COP is intended to keep electronics cool. It's not. phones and tablets, if left in the car or outside do indeed shut down due to battery safety mechanisms. For most devices, that threshold is around 60C. At those temps, your battery is at risk of thermal runaway if you use it heavily (think phone fire or explosion).
There's no electronics in the dash that is sensitive to max temps of an enclosed cabin in a hot summer. The battery is safe underneath the cabin and is only susceptible to shade temps and radiative heat from the ground under it.
Silicon circuitry can withstand very intense heat. CPU/GPU chips traditionally are designed to operate correctly to 80C but modern chips can go even higher, near boiling temps. Risk of hitting these temps are not environmental at all; they are from waste heat caused by its own operating power. There are dedicated heat sinks and cooling systems in place for these components.
Earlier in the Spring, our pal Montana Septic speculated that the anecdotal reports of phantom touches on the touchscreen was due to high cabin heat, and that this summer, we would see a widespread recall of screens as the heat destroyed all the touchscreens. Did not come to pass.
There is no cause for FUD here.
Absolutely. The BMS is always active and will heat or cool your battery as necessary. It is necessary in both hot/cold extremes.Very informative post. Thank you very much!
Is there an active system within a model 3 that monitors battery environment or keeps batteries cool on hot days? Is that necessary or an issue?
