juliusa
Yes - if your SOC% suddenly drops by 4-6 percentage points there is something wrong. Time for a service appointment.I've witnessed both drops "live" so to speak
I'm not saying the canbus values are misreported, I am saying that what they actually are representing may be misunderstood, since only Tesla knows what they mean. That's why I asked you about your nominal full pack value reading.Not sure why the canbus values would be misreported.
Nominal value divided by EPA consumption is the exact number listed for rated range. When the battery gets below 20% on a long trip, the car begins to use the usable value divided by EPA consumption. It's really not a misunderstanding, the car is giving you information based on one value, then on a completely different value. And it refreshes on it's own, hoping the driver won't notice.I'm not saying the canbus values are misreported, I am saying that what they actually are representing may be misunderstood, since only Tesla knows what they mean. That's why I asked you about your nominal full pack value reading.
I agree there is something strange going on, but I don't think the 290 Wh/mi number is from the EPA. I think the only numbers that come from EPA is rated range and kWh/100 miles, the later which includes charging and other internal battery losses. I think Tesla uses that 290 number but it doesn't match actual performance. In my car, I consume rated miles at 270 Wh/mi, regardless of what percent charge my battery is reading. I never achieve rated miles at 290 Wh/mi. But when I charge my battery, it charges at close to 290 Wh/mi.Nominal value divided by EPA consumption is the exact number listed for rated range. When the battery gets below 20% on a long trip, the car begins to use the usable value divided by EPA consumption. It's really not a misunderstanding, the car is giving you information based on one value, then on a completely different value. And it refreshes on it's own, hoping the driver won't notice.
@wk057 confirmed the watts per mile used for each EPA calculation for each model. I think some people are confused about Tesla "changing" the algorithm. They can improve the estimation and the prediction of the battery degradation and the "remaining" range can be adjusted based on weather conditions for trip estimation. But they can't just change the EPA rated watts per mile to lie to the customer.I agree there is something strange going on, but I don't think the 290 Wh/mi number is from the EPA. I think the only numbers that come from EPA is rated range and kWh/100 miles, the later which includes charging and other internal battery losses. I think Tesla uses that 290 number but it doesn't match actual performance. In my car, I consume rated miles at 270 Wh/mi, regardless of what percent charge my battery is reading. I never achieve rated miles at 290 Wh/mi. But when I charge my battery, it charges at close to 290 Wh/mi.
In any case, I think only Tesla could explain what is really going on, but they might not want to.
I don't think @wko57 claimed that number came from the EPA. He showed that it is used by Tesla, not that it comes from the EPA, or used in any EPA calculation. The only EPA spec numbers I have seen are rated range and kWh/100 miles. EPA doesn't give any Wh/mi number, at least I've never seen it.@wk057 confirmed the watts per mile used for each EPA calculation for each model. I think some people are confused about Tesla "changing" the algorithm. They can improve the estimation and the prediction of the battery degradation and the "remaining" range can be adjusted based on weather conditions for trip estimation. But they can't just change the EPA rated watts per mile to lie to the customer.
If my car actually displayed ~250 miles on a full 100% charge, then we wouldn't be in this thread. But if it did say that, then I'd be barking at Tesla that 15% range degredation is completely unacceptable for a 2.5yr old car.
. 90D pre-refresh nominal capacity 85.8kwh
B. 90D pre-refresh usable capacity 81.8kwh
C. 4kwh brick protection, cannot use (A minus B)
D. Watts per mile used to calculate EPA rated range for pre-refresh 90D, 290 watts per mile.
I must be missing something, isn't Wh/mile just kWh/100 miles multiplied by 10?
Edit: ah, I see from a couple posts earlier you call out that that includes charging losses.
You item D may be incorrect.
The 2015 S90D was EPA rated at 340 Wh/mile (34kWh/100 miles)
Gas Mileage of 2015 Vehicles by Tesla
Interesting that 340 watts per mile is the EPA number. And if that's the case, then where can they possibly get the other numbers from?
My hang up is this: Whichever way you slice it, Nominal or Usable, you get two numbers. And only one of those numbers faces the owner; the other is never seen anywhere. Assuming that consumption you listed is right, here are all the variations based on 290 and 340 w/m:
New (based on wk057 research)
85.8 nominal brand new
290 w/m = 294 miles (this was actually advertised, correct?)
340 w/m = 249 miles
81.8 usable brand new
290 w/m = 282 miles (wasn't there some advertising that the 90 was 6% better than the 85kwh?)
340 w/m = 240 miles
Brand New Observed After 1 Month
290 miles
84.1kwh (nominal)
80.1kwh (usable)
Now
78.9 nominal
290 w/m = 272 miles (this is the number I see on the dash)
340 w/m = 232 miles
74.9 usable
290 w/m = 258 miles
340 w/m = 220 miles
whereas the later 90 was a software limited 100 pack
I have never heard this before, do you have any links to back that up?
340 w/m = 249 miles
340 w/m = 240 miles
290 miles
84.1kwh (nominal)
80.1kwh (usable)
Now
78.9 nominal
340 w/m = 232 miles
74.9 usable
290 w/m = 258 miles
340 w/m = 220 miles
Here is what I think is happening and is probably consistent with at least some of what you have observed:Brand New Observed After 1 Month
290 miles
84.1kwh (nominal)
80.1kwh (usable)
Now
78.9 nominal
340 w/m = 232 miles
74.9 usable
290 w/m = 258 miles
340 w/m = 220 miles
I have a totally uninformed question to ask about all this, as I'm not following this very well. How do we know what the car's battery is able to do? I thought you cannot know the battery capacity while using it.
Aren't all of the number coming from the car just current estimates? The car is guessing how far it thinks you will get based on the battery charge and how you drive the last x miles. If I drive my car like a bat out of hell, uphill, against the wind, my numbers will suck, go the other direction, it's super. Aren't your range number always in flux. MY car only has about 11k miles and it's settling into around 280 wh/mile.
Not trying to cause and issue, just trying to catch up to the concern of battery degradation. We just have to make sure we are getting good numbers... right?
I have about a 2 million row CSV file I'm working on right now that tracks and entire discharge cycle from 100% to 5%.
