IC replacement not working
Gu$ G
130
33
Kaneohe, HI
My buddy purchased an IC from Realdeel and he just got it installed. The car is only illuminating about half of the screen, and the image is pretty distorted and not working. Anyone seen this happen before? He initially tried swapping the IC without disconnecting the HV, but even after removing HV / 12V power he still can't get this issue to clear with a reset. Anyone seen this before?
kdday
1,132
2,543
AZ
assuming this is on an mcu1 car, IC is a standalone computer that has to be firmware matched to the cid. Depending upon the firmware both the Ic and cid are currently running, and if you have Ethernet access to the car network, this can be easy or hard.
But I just want to warn you that assuming you get the lcd issues resolved, the ic will need a firmware redeploy before it’ll talk to the car correctly.
oh, and until you get it working, gateway will NOT charge your 12v battery until the redeploy is successful. So watch your 12v battery voltage because you could kill your 12v battery in a few hours.
Doanster1
843
454
Oregon
Realdeel not sold replacement screens, not the entire IC so if the prob just is a loose/misaligned connection they should be golden.
uscgreel
33
15
Tampa, FL
Chad from reeldeal messaged us back and thinks this is a misaligned ribbon cable. Will report back, thank you for the quick reply Chad!
You are welcome, we actually added an update to our site about your scenario, just be extra sure the ribbon cables are completely seated. ;)
