I’ve found a bunch of ice in the lower part of the boot of my m3 - thought it was initially from frozen water bottles but seems it was from water leaking in through the seal at bottom of the door (presumably when I was pressure washing);
None of this was visible until it froze - I removed the boot lining and it’s also soaked into all the insulation under the boot - it’s currently been drying out for last few days.
Just mentioning it here should anyone else be noticing ice in this part of the boot - it’s worth pulling the lining out (it’s held by Velcro all around and 2 clips below the plastic cover at the door latch) and check it’s not soaked into the insulation on the bottom - no idea how long it’s been leaking for - but given amount of water it’s probably done it since I got the car 2 years ago!
On a side note if anyone else has had this - do I actually need the insulation on the bottom of the boot cover - it seems it’s mainly there to stop noise - wondering if I’m as well throwing it as it’s been totally soaked in water for a long time.
