M myemail New Member Nov 20, 2020 1 1 Australia Nov 20, 2020 #1 Nov 20, 2020 #1 Using web to navigate to icloud.com brings up "Sign in to iCloud. The Apple ID prompt goes "big grey box" when you tap to enter. Anyone see this? becomes: Reactions: klmc
JulienW Well-Known Member Jul 7, 2018 6,873 11,584 Atlanta Nov 21, 2020 #2 Nov 21, 2020 #2 Been a while back (pic Jun 19) but I signed in before. I will they later today. Reactions: KenC
K klmc Member Feb 12, 2021 26 21 Monaco Mar 16, 2021 #3 Mar 16, 2021 #3 I get the same grey box as the original poster - anyone found a solution?
K klmc Member Feb 12, 2021 26 21 Monaco Mar 16, 2021 #4 Mar 16, 2021 #4 Does this still work for you? JulienW said: Been a while back (pic Jun 19) but I signed in before. I will they later today. View attachment 610493 View attachment 610494 Click to expand...
JulienW Well-Known Member Jul 7, 2018 6,873 11,584 Atlanta Mar 16, 2021 #5 Mar 16, 2021 #5 klmc said: Does this still work for you? Click to expand... Sorry, haven't tried it over a year. I will try and remember to give it a try. Reactions: jjrandorin
JulienW Well-Known Member Jul 7, 2018 6,873 11,584 Atlanta Mar 19, 2021 #6 Mar 19, 2021 #6 Tried this morning and it didn't work. When I tried to select the Apple ID box I then get a gray block.
TBrownTX Active Member Dec 25, 2020 1,271 1,500 Dallas, TX Mar 19, 2021 #7 Mar 19, 2021 #7 JulienW said: Tried this morning and it didn't work. When I tried to select the Apple ID box I then get a gray block. View attachment 645886 Click to expand... Do you have two factor authentication enabled? I'm curious if that might cause some login issues. Tim
JulienW Well-Known Member Jul 7, 2018 6,873 11,584 Atlanta Mar 19, 2021 #8 Mar 19, 2021 #8 TBrownTX said: Do you have two factor authentication enabled? I'm curious if that might cause some login issues. Tim Click to expand... That could be it.
K klmc Member Feb 12, 2021 26 21 Monaco Mar 23, 2021 #9 Mar 23, 2021 #9 I too get the gray box and yes 2FA enabled Reactions: TBrownTX
