Idea: Consistent Behavior in Standard Regeb mode on newer vechiles
Discussion in 'Model S: Driving Dynamics' started by wk057, Oct 31, 2014.
  1. wk057
    wk057 Senior Tinkerer
    Hickory, NC, USA
    So, not sure if anyone has thought of this, just figured I'd share a thought I had while driving my cold Model S this evening...
    As we all know, when it gets cold or when you're at a high state of charge regen is limited. No way around this, and it changes the feel of the vehicle for a while until max regen is available.
    Well, I wonder if it would be possible to utilize the new electric-mechanical braking system to make the car behave the same in all conditions by applying friction braking to make up for the power not able to be absorbed through regen? The dash could perhaps show a green line up to the the regen point and grey beyond there where the car is using the brakes to "simulate" regen.
    This is a feature I personally would keep enabled if it existed... thoughts?
  2. AoneOne
    AoneOne Member
    Fox Chapel (Pittsburgh), PA
    Why not use the regen power to warm the battery so it can then absorb further regen? Or at least, use the regen to heat the cabin?
  3. wk057
    Hickory, NC, USA
    Pretty sure it does this already, but those loads are negligible compared to the 60kW produced at full regen. (Battery heater + cabin heater is only something like 4-6kW if I recall correctly).
  4. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Cabin and battery heaters are each capable of 6 kW. In my experience regen limit doesn't take this load into account.
  5. Cottonwood
    Colorado
    This has been my experience as well.
  6. wk057
    Hickory, NC, USA
    Even if it did, that load is still nothing when looking at a 60kW potential regen output.
