K-MTG
Sunshade Captain of TMC
For some reason it is not letting me rate this post funny
Some things are too true to be funny.For some reason it is not letting me rate this post funny
OK lets call it hilarious. I'm still laughing.......loved it ohmman.Some things are too true to be funny.
Having learnt that early on with the Model S, I noticed first with Model S and then with the X after the most recent software update that the car wouldn't change lane when on autosteer unless there was sufficient clearance (like I could see the front wheels of the vehicle behind me in that lane). The lines changed from solid to dashed after there was a safe distance. Maybe TM improved the feature. However, I don't know how it will work if another car would move into that space while my car is about to change lanes. It's not a scenario I run into every day in my commute.On Model S, I would almost trust Autopilot enough to not do a shoulder check. But there isn't rearward facing radar so it can't see vehicles charging up behind you in the lane you're about to move into, so you could inadvertently cut someone off or get rear-ended if you don't make sure the lane is clear yourself.
Yeah, I mean, if there is a vehicle within the 2m (?) radius of the vehicle, the ultrasonic sensors will see it and the Model S won't change lanes. So in this way it is a sort-of substitute for shoulder checking. However, if there is another car roaring up from behind which is too far away for the car to "see" but will be in the way as soon as the Model S starts to change lanes, that's where this is an issue. There is no way the Model S with the current sensor suite can see this coming. So, not quite a 100% substitute for a good ol' over-the-shoulder and glance at the mirror. Yet.Having learnt that early on with the Model S, I noticed first with Model S and then with the X after the most recent software update that the car wouldn't change lane when on autosteer unless there was sufficient clearance (like I could see the front wheels of the vehicle behind me in that lane). The lines changed from solid to dashed after there was a safe distance. Maybe TM improved the feature. However, I don't know how it will work if another car would move into that space while my car is about to change lanes. It's not a scenario I run into every day in my commute.
Don't open your FWDs and garage door at the same time. The FWDs will see open space above and open fully. The garage door mechanism will then move and hit the edge of the FWDs.
Usually you're the one in control, though. With passenger doors, kids often are.If I trigger the power rear hatch door on my Mercedes GL450 at the same time as my garage door, there is a good chance of collision. My solution is to not do that.
Correct. However, if it does see something there, the lane change operation will not proceed. I've tried doing lane change before and found the car waiting for more clearance.
