Idle Battery Drain Significantly Reduced?
johnmodely
256
182
NY
Looks like battery drain has been finally put under control with one of the recent 20.16.x releases. Parked my car at 60% on friday morning with sentry mode on, and its still at 58% as of now. Pretty impressive, since it was draining around 4% a day with sentry mode on before, and 1-2% a day even when it was sleeping.
Young Phenom
312
277
Florida
Outside or in the garage?
Overheat protection on?
Picasso
kllkkjlk
May 8, 2009
218
113
Also seeing a big reduction when charging, I charge off a 2500watt solar system 120v 9amps when the sun is out and I'm seeing a reported mile per hour charge increase and seems to be making less noise on the charging. Seems likes its worked out it dosnt need to cool the cells at such a low charge rate. been silent most of the times ive walked by.
