@kwest2 you ever figure out your problem?
It sounded like in another thread high ~1mi/hr drain can be due to the car trying to download an update continuously in the background. Allegedly...it sounds like that is perhaps a made-up answer from Tesla though.
There is some other theorizing over there about bad states and such with various proposed workarounds but no one seems to have the perfect solution yet. Not surprisingly.
Lost 51 miles of range in 53 hours?!
In any case, whatever the issue, it results in the car staying in idle mode. And this type of problem is likely the reason for your high drain. Somehow you have to find a way to kick it out of idle mode to sleep.
Someone in the other thread made me aware of the iOS Widget. It says the car is “Asleep” right now for me, rather than “Parked”. I don’t know how in sync this info really is (it has a refresh on the widget...which wakes the car up...it may be useless), but maybe (other than a 3rd party app) it would provide a means of seeing what mode the car is in?
Obviously can park near strong WiFi, keep it plugged in, etc. and hope for the best. (I know all may not be possible...if you could keep it plugged in you would care a lot less!)
While this is a particularly bloodthirsty vampire problem (and presumably a bug), I think this demonstrates that vampire drain is a completely solvable software problem, if Tesla would prioritize minimization of standby drain.
And if they get the sleep mode power down to solidly below 5W, and avoid idle mode, then I think there will be very few complaints. Should be possible! Just do it, Tesla! Almost there!
Aside:
On the other topic of
rated range vs. ambient temp.
@coleAK is helping gather some data, since I didn’t get a response here.
So far, rated range is not significantly impacted with the battery/ambient as low as 13F. Still ~310 miles. It’ll be much colder next week though.
Of course the car may be expending energy to condition the battery for that data (maybe battery is not at 13F), but there is no way to prevent that, so it’s valid. Final results will probably post to his thread.
We’ll see.
