The manual has instructions on how to pop the frunk when the 12V battery is dead:If my wife comes out of the store and 12 volt battery just died what does she do? Can't get into the car, where I've stashed instructions and a small charger in the trunk.
She Can't open the car door, no emergency hard key, can't open the trunk or the frunk.
If you want to prepare for a situation with no outside help, you can stash a small 12V A23 battery in a small zip lock bag (to prevent corrosion) behind your tow hook cover. That can be used to pop the frunk in case the 12V dies. You can have instructions in there too if it fits. Then leave your jump starter in your frunk instead of trunk.
I did that about a year ago, and fortunately haven't had to use it yet. Someone saw me stuffing the battery in the tow hook spot, and joked that I now I could "hot wire my frunk". Pretty much, yeah.If you want to prepare for a situation with no outside help, you can stash a small 12V A23 battery in a small zip lock bag (to prevent corrosion) behind your tow hook cover. That can be used to pop the frunk in case the 12V dies. You can have instructions in there too if it fits. Then leave your jump starter in your frunk instead of trunk.
On that subject, A23s have self discharge, Duracell rates their's at 10% per year. So probably makes sense to check voltage or swap new ones in if they have been there for a while to avoid situations of it being out of charge (or perhaps have a few so they can be used in parallel to reduce voltage sag, which might help if they are lower on charge).I did that about a year ago, and fortunately haven't had to use it yet. Someone saw me stuffing the battery in the tow hook spot, and joked that I now I could "hot wire my frunk". Pretty much, yeah.
I did find the instruction for this procedure after posting the question. and intend to get the 12 volt A123 and will post the instruction on her phone.The manual has instructions on how to pop the frunk when the 12V battery is dead:
Model Y Owner's Manual | Tesla
As does the DIY Guides:
Model Y Do It Yourself | Tesla
For most people, it's a simple matter of calling Tesla Roadside or AAA and they can send someone with a jump starter to pop the frunk and jump start the car.
OOOOooo. I don't like thatOn that subject, A23s have self discharge, Duracell rates their's at 10% per year. So probably makes sense to check voltage or swap new ones in if they have been there for a while to avoid situations of it being out of charge (or perhaps have a few so they can be used in parallel to reduce voltage sag, which might help if they are lower on charge).
https://www.duracell.com/wp-content/uploads/2020/02/MN21_0620192.pdf
I should note there are probably corner cases where the 12V battery in the car is in a middle state: not enough charge to power the car's locks, but enough charge that the frunk can't pop. Just a warning this is a possibility.
Now wondering if one gets a warning that it is fixing to die.
With the latest software updates, there is less worry of this as the car checks up on 12V battery health automatically and will keep the car awake if it detects the 12V battery is failing and will give a warning.ha funny
The cigarette outlet voltage is the voltage from DC-DC converter. To know the 12V battery voltage you need to check the actual 12V battery terminal with the car asleep. However, just knowing the battery voltage doesn't tell you much about its health. An actual test with a load tester with battery disconnected from car is typically how it is officially done. Some people have a wireless battery monitor to check how it is charging/discharging, but I don't think it necessarily will tell you how battery health is doing.And..... have a little jump starter battery in the frunk. thanks. Now wondering if one gets a warning that it is fixing to die. see that one can measure the voltage at the cigarette lighter and maybe infer that battery is getting weak. I did measure it yesterday to be 14.5 but is this while the battery pack is charging it up? I must determine when is the best time to measure it to know if its weak, anyone know?
The detection is not perfect (sometimes batteries can seem fine all the way up until it fails). Some of the older batteries (like from the original 2018 bunch) may have been damaged more before Tesla adjusted the 12V charging/detection mechanisms. The OP didn't mention the battery actually failed yet, I was presuming he was looking to prepare for that occasion.Good to know it’s there now.
Wonder how his wife didn’t get the message then? Loose connection isn’t of bad battery? I would think this would be a message too though.
Right, just trying to prevent a problem before it happens.The detection is not perfect (sometimes batteries can seem fine all the way up until it fails). Some of the older batteries (like from the original 2018 bunch) may have been damaged more before Tesla adjusted the 12V charging/detection mechanisms. The OP didn't mention the battery actually failed yet, I was presuming he was looking to prepare for that occasion.
hasn't happened, just trying to prevent it from happening.Good to know it’s there now.
Call AAA or call Tesla for roadside service (actually, use the app).
Plug in the Tesla Model Y and leave Sentry Mode on or set Camp mode with HVAC fan only on Low. The Tesla Model Y will remain powered on, not enter sleep mode. In this way the Tesla Model Y's 12V systems are powered by the on-board power conversion system DC-to-DC power inverter, not the 12V battery.Funny enough I just for the messages. Yes multiple messages. Coincidently, I already had mobile service scheduled for repeater cameras (turn signal flash), rear camera trunk cable harness and a clicking from wheel well when turning hard right.
I have a long trip tonight I hope the battery holds up till tomorrow. Especially since the learn more notes says car MAY power off while driving and / or might not turn on the next time after being turned off.
The on screen message states non essential items will be shut off like radio, nav, HVAC, seat heaters.
