Note: This feature currently requires accessing the site using the built-in Safari browser.
No depressing of the brake. All cars, cars and trucks must be able to switch between drive and neutral without depressing the brake or a button to move the lever. This is so if the car excelerater pedal gets stuck or engine stalls you can either brake or start the vehicle.Yes you can, but I believe you will have to depress the brake to do it.
is the excelerator the pedal between the brake and the accelerator? is it like an extra pedal?No depressing of the brake. All cars, cars and trucks must be able to switch between drive and neutral without depressing the brake or a button to move the lever. This is so if the car excelerater pedal gets stuck or engine stalls you can either brake or start the vehicle.
Nah man its that peddle on the right. (what the heck was I thinking, like spelling break for brake)is the excelerator the pedal between the brake and the accelerator? is it like an extra pedal?
Wait, the parking brake is automagically applied? I though it was applied by holding in the Park button on the gear selector? Doing that is what causes the parking brake indicator to appear on the dash panel of the MFD, at least.
The model S will shift from D - N - D fine when moving.The S and X require pressing the brake in order to shift from N to D. I don't have a 3, so I can't say about it.
Hmmm. That's what I would think the logic would be (from my years of ICE driving), but I swear today when I left the car wash (in neutral) and tried to shift into drive, it made me hit he brake. I'll try again next drive.No depressing of the brake. All cars, cars and trucks must be able to switch between drive and neutral without depressing the brake or a button to move the lever. This is so if the car excelerater pedal gets stuck or engine stalls you can either brake or start the vehicle.
As mentioned before here, coasting in neutral has the benefit of saving energy. Using regen 100% of the way down a slope will net you some losses by converting the kenetic potential energy to energy stored in the battery. If you can coast in neutral safely without breaking the speed limit, you'll save energy overall.
It is the pedal you press to pursue excellence, of course.is the excelerator the pedal between the brake and the accelerator? is it like an extra pedal?
GA Law said:(a) The driver of any motor vehicle when traveling upon a down grade shall not coast with the gears or transmission of such vehicle in neutral.
I'm not 100% certain what, if anything, changes physically when you hold the Park button while stopped.
There isn't a parking pall in any Tesla drive unit. Shifting to park sets the 12V electronic parking brakes on the rear wheels - with HVAC off in a quiet place you can hear them engage.
I know holding it while moving is the emergency braking solution...
Note that in most states this is illegal- including yours.
2010 Georgia Code :: TITLE 40 - MOTOR VEHICLES AND TRAFFIC :: CHAPTER 6 - UNIFORM RULES OF THE ROAD :: ARTICLE 11 - MISCELLANEOUS PROVISIONS :: § 40-6-246 - Coasting
(b)The driver of a truck or bus when traveling upon a down grade shall not coast with the clutch disengaged.
You can hear that thing engage/disengage with the HVAC on max in quite a loud place!I'm not 100% certain what, if anything, changes physically when you hold the Park button while stopped.
