If No Regular Charging Outlet, Is Supercharging Once a Week Ok?
Discussion in 'Model X: Battery & Charging' started by bayx, Jul 29, 2018.
  1. bayx
    bayx Member
    San Francisco
    I will be using my MX for short commutes (< 130 miles/week). I do not have access to a wall charger since I temporarily rent an Apt for another 7 months. So the only option I have to charge is the supercharging station. Would charging at a supercharging station for the next 7 months be ok for the batteries? How does this impact battery life, if at all?
    People on this forum talk about the 12v battery going dead - can someone please elaborate what this means? Thx.
  2. SSedan
    SSedan Active Member
    Greenville Wisconsin
    12volt is a small battery used to power electronics, it is drained and recharged something like 4-5 times a day, supercharging would have zero impact on that.
    Far as on the main battery, do what you have to but avoid spending time below 10% or above 90%, going past those limits is OK just don't leave it there.
  3. P85_DA
    P85_DA Supporting Member
    Since I commute a lot I hit superchargers several times a week ...nothing to worry about (except being overcrowded lol ) ....did for both my S and now X and nothing significant on battery degradation ...
  4. CSFTN
    CSFTN Member
    Memphis, TN
    Any parking garages nearby? Might be able to convince owner to install a couple of wall chargers ....Tesla sometimes gives them away. Then less time spent driving to Supercharger.
  5. Yinn
    Yinn Active Member
    Behind you
    I met someone in the same situation at the SCs, not sure they're on the forums though. Retirement transition and in an apt rental now for a little over a year and their only option is a SC (or destination L2's) I'm not sure on the frequency, but they basically grab it when they can and according to them it's 15-30 minutes at a time so they're probably not charging it to max and it was their way to keep the battery from degrading. True enough they showed up after me and left well before me...I sat for another 40 minutes.
  6. Skidmark
    Skidmark Member
    San Jose, CA
    Someone told me that when supercharging, all electronics and the air conditioner is run only off the 12v battery. If this is true, it could explain premature failure of the 12v battery if owners sit in the car while supercharging and leave the air on.
  7. SpudLime
    SpudLime Active Member
    Leesburg, Va
    Interesting. I would like to know the answer of this as well.
  8. Electric700
    Electric700 Active Member
    Florida, United States
    OP, you could check out PlugShare.com, and there's an app for that. I'd also talk to the owner about installing charging, as I expect the need to charge EVs to grow greater to the point that chargers should become standard equipment for new homes (as part of building codes) along with solar / wind power.
  9. bayx
    bayx Member
    San Francisco
    Thanks all for the info. Talked to Apt management about installing chargers and they were pretty open to the idea.
  10. bayx
    bayx Member
    San Francisco
    Maybe Tesla could shed more light on this, I should ask this at delivery and post their response later here.
  11. nwdiver
    nwdiver Well-Known Member
    United States
    No; I'd be surprised if any of the fans even ran on 12v. ~99% sure it's only the electronics.
  12. DarkMatter
    DarkMatter Active Member
    Olympia, WA
    No way it could be the case. The chiller can take several kW. It would drain the 12V in minutes.
